| Tubing bender ASAP | |
| Subject: Tubing bender ASAP Wed Aug 22, 2007 6:19 pm | |
| I've looked at a lot of tubing benders and the most popular "inexpensive" bender is the JD2 model 3 at $295....plus $135 for a stand, plus $40 for a handle to operate the bender, plus $215 for the dye. and suddenly its not so cheap anymore. Anyone want to part with a used bender or rent one out to me? | |
| Subject: Re: Tubing bender ASAP Wed Aug 22, 2007 10:34 pm | |
| sunbelt rentals has a bender that you can rent if no one has one. | |
| Subject: Re: Tubing bender ASAP Thu Aug 23, 2007 9:14 am | |
| never thought of that, thanks I'll look into that | |
| Subject: Re: Tubing bender ASAP Thu Aug 23, 2007 5:59 pm | |
| Do they rent one's that have die's large enough for the tubing you need or is it a bender for conduit like a electrician uses??? Ask them for the die sizes before spending the money.. If they do, thats Great to know!!! I have been wanting to make a new Stinger for my buggy.. | |
| Subject: Re: Tubing bender ASAP Thu Aug 23, 2007 7:57 pm | |
| the one I saw was huge, it looked like you would use it for for industrial pipe. | |
Twisted Willys Locker/Locker
| Subject: Re: Tubing bender ASAP Fri Aug 24, 2007 10:19 am | |
| I have a pipe bender you are welcome to use any time(as long as i'm not in the middle of using it). It works great and has many different dies. 1/2" to 2".I used it to build my entire exocage. That was extra heavy wall pipe! Let me know if you want it,when you need it and about how long you will have it. | |
| Subject: Re: Tubing bender ASAP Fri Aug 24, 2007 1:05 pm | |
| AWESOME! My biggest need right now is building front shock hoops. the tubing should be in on Mon or Wed next week. I'll call to set something up once I get the tubing and have the specifications. I will be using 1.25" .125 DOM and bend almost 180 degrees. Still working out the details of how to reinforce the mount. In a couple weeks I'll be building tube fenders for the rear that will implement a 6" fender and will need the bender then if the timing works out ok for you. I appreciate this Dave and will call you next week. Thanks again. | |
| Subject: Re: Tubing bender ASAP Sat Aug 25, 2007 10:31 am | |
| Hey, No problem. It's a cheap Harbor Freight deal but it works quite well.It's at work all of the time. I shouldn't really need it for a while. I might need it to build some shield supports, but that wont be for a few weeks. With you being close when you go to work if I want it back for a day or two it shouldn't be a big deal to work out. I got my trans. mocked in for now, transfer in and clocked, SYE kit should be here late this week.Shifter kit comes Tue.. Then on to driveshaft woes. I expect my trans rebuild guy to call asking for it this week. I might actually be running in a few weeks. The "bullet proof pieces for the tran.s all came from ebay and that saved alot of $. the way this is going to be built, I shouldn't have any more trans/transfer troubles! It's time to break something else for a change! I might even come out of this with a front locker. talk to ya later | |
| Subject: Re: Tubing bender ASAP Sat Aug 25, 2007 4:35 pm | |
| Cool, Glad to hear things are coming along for you. I'll give you a call when the time is close. Thanks again. | |
| Subject: Re: Tubing bender ASAP | |
