| Axle / U-joint replacement? | |
+4Rockn93YJ makitupthehardway el_flasko lloyder05 8 posters |
lloyder05 Locker/Spool
Number of posts : 210 Age : 50 Localisation : Bel Air, MD Registration date : 2007-01-31
| Subject: Axle / U-joint replacement? Sun Nov 25, 2007 11:41 pm | |
el_flasko LS/Locker
Number of posts : 53 Age : 50 Localisation : Abingdon, MD Emploi : Resident Mortgage Guy Registration date : 2007-11-07
| Subject: Re: Axle / U-joint replacement? Sun Nov 25, 2007 11:48 pm | |
| That sucks man...looks like it's time to pull it and see. I had something similar on my TJ, turned out the shaft (inner) was twisted as well. Check it all while you have it apart to be sure. | |
| Subject: Re: Axle / U-joint replacement? Mon Nov 26, 2007 5:50 am | |
| Hey Chris, I think you should upgrade to some chromo shafts. I'm not sure what the price is but I think Nick found a good deal on usa alloy and super joints for under 400. (i think) What those tires and wheeling it often you going to have that happen every 3 or 4 months if you wheel it hard and 6 or 7 if you take it easy. If you looking for stock replacement check the boards and ebay for deals. | |
| Subject: Re: Axle / U-joint replacement? Mon Nov 26, 2007 9:10 am | |
| Yeah I agree with Eric on this. Might be able to keep this as an emergency spare. | |
| Subject: Re: Axle / U-joint replacement? Mon Nov 26, 2007 12:26 pm | |
| Yeah you should be able to jam a new spicer joint in to that axle but since it has been bent I wouldn't run on it but it will make a great spare. I still haven't seen anyone bust a chromo Dana 44 shaft. | |
| Subject: Re: Axle / U-joint replacement? Mon Nov 26, 2007 2:21 pm | |
| chris, Let me check with Jack over on creepers. Him and I were looking to swap his rubi and my buggy a few months back and he had a set of usa's for it. Let me see if he still has them. | |
| Subject: Re: Axle / U-joint replacement? Mon Nov 26, 2007 2:36 pm | |
| That would be great Matt! Thanks.
Thanks Ryan, Nester and Bill for your advice! | |
| Subject: Re: Axle / U-joint replacement? Mon Nov 26, 2007 3:05 pm | |
| - Quote :
- I still haven't seen anyone bust a chromo Dana 44 shaft.
von did this week end, I think | |
| Subject: Re: Axle / U-joint replacement? Mon Nov 26, 2007 3:21 pm | |
| Yeah - Von broke the driver side shaft on Tombstone coming up on the far left side. Chris - Did the cap just fall out? Every u-joint I've removed has been a PITA to get the caps out. | |
| Subject: Re: Axle / U-joint replacement? Mon Nov 26, 2007 3:35 pm | |
| No, it shattered out of there. https://i.servimg.com/u/f22/11/24/21/66/dsc04010.jpg | |
| Subject: Re: Axle / U-joint replacement? Mon Nov 26, 2007 3:41 pm | |
| Chris call me.. I cant find your cell.. He has front and rear.. | |
| Subject: Re: Axle / U-joint replacement? Mon Nov 26, 2007 8:38 pm | |
| yes, i had chrome moly shafts with yukon super joints and i snapped the ears off of the drivers side outer, i might be able to just get new caps for the joint and put it back together with a new outer so nester now you know someone who has | |
| Subject: Re: Axle / U-joint replacement? Mon Nov 26, 2007 10:12 pm | |
| Von nothing surprises me with you. Plus Von is a big fan of the skinny petal. At the same time has made plenty of lines I haven't. | |
| Subject: Re: Axle / U-joint replacement? Mon Nov 26, 2007 11:03 pm | |
| Chris, did you get ahold of him? | |
| Subject: Re: Axle / U-joint replacement? Mon Nov 26, 2007 11:59 pm | |
| Called and left a message this afternoon. I'll try again tomorrow. | |
el_flasko LS/Locker
| Subject: Re: Axle / U-joint replacement? Tue Nov 27, 2007 1:11 pm | |
| Jack's a good guy Chris, I'm sure he'll hook you up. Let me know if you need a hand with anything once you decide which way you're going | |
| Subject: Re: Axle / U-joint replacement? Tue Nov 27, 2007 1:15 pm | |
| Thanks Ryan, I'll keep you informed of what I figure out | |
| Subject: Re: Axle / U-joint replacement? | |
