 Front Driveshaft U-Joint replacement
+5
ne14jpn
9 posters
Number of posts : 695
Front Driveshaft U-Joint replacement Empty
PostSubject: Front Driveshaft U-Joint replacement   Front Driveshaft U-Joint replacement Icon_minitimeSun Feb 18, 2007 10:47 pm
I developed a bad vibration at 40 mph recently. The last few days there was an awful knocking under my feet. I pulled the front DS and the vibes and noise wet away. I bought new u-joints, but don't know how to go about replacing them. Any advice is appreciated.
Thanks,
Dan
Tryig to remove the u-joint:
Front Driveshaft U-Joint replacement Driveshaft023
Dent from a rock:
Front Driveshaft U-Joint replacement Driveshaft020
PostSubject: Re: Front Driveshaft U-Joint replacement   Front Driveshaft U-Joint replacement Icon_minitimeSun Feb 18, 2007 11:42 pm
Danny if I were you I would take the drive shaft to a drive line shop or a mechanic shop and have them rebuld the CV and press in a new joint. It will save time and it shouldn't cost more than 100 bucks. You might find someone with a press or that is willing to help but sometimes its nice to let someone else do the dirty work Very Happy
PostSubject: Re: Front Driveshaft U-Joint replacement   Front Driveshaft U-Joint replacement Icon_minitimeSun Feb 18, 2007 11:43 pm
here you go I love this site tons of info
http://www.stu-offroad.com/axle/driveshaft/driveshaft-2.htm
PostSubject: Re: Front Driveshaft U-Joint replacement   Front Driveshaft U-Joint replacement Icon_minitimeTue Feb 20, 2007 10:58 am
I dropped it off at A1 driveline this morning. they said it has to be re-tubed....all cause of that 1 little dent. If I'm gonna have it retubed I want it to be because of something cool like it sheares in half like Matt's did.
Oh well....
He also said the pin on the transfer case side is likely bad. He's gonna press in the new u-joints for me as well. There was a dark mark where the D/S has been contacting the transfer case skid.... I might have to do some cutting there.
Rich - they had a german shepherd guard dog there at the shop.....He could use a few pointers from Skylar!
PostSubject: Re: Front Driveshaft U-Joint replacement   Front Driveshaft U-Joint replacement Icon_minitimeTue Feb 20, 2007 11:57 am
Good choice in sending it to the shop. I will only change my own if it is a trail repair now. The fact that the shaft had a dent could mean the vibration was from a bent shaft and replacing the u joints may not have cured the problem. The u joint replacement can be a headache if not done right.
ne14jpn
ne14jpn
Number of posts : 53
Registration date : 2007-01-21
PostSubject: Re: Front Driveshaft U-Joint replacement   Front Driveshaft U-Joint replacement Icon_minitimeTue Feb 20, 2007 2:03 pm
since they are retubing it, make sure they increase the wall thickness of tube.
http://www.myspace.com/millerrockracing
PostSubject: Re: Front Driveshaft U-Joint replacement   Front Driveshaft U-Joint replacement Icon_minitimeTue Feb 20, 2007 7:06 pm
Not eveyone can be like me danny Razz jk. It was a good idea getting that retubed cause that dent makes the driveshaft very weak.
projblacknblue
projblacknblue
Number of posts : 297
PostSubject: Re: Front Driveshaft U-Joint replacement   Front Driveshaft U-Joint replacement Icon_minitimeTue Feb 20, 2007 9:33 pm
Hey Danny...
Just curious... was that the source of your "sherman tank" noise squeaking down the trails?
PostSubject: Re: Front Driveshaft U-Joint replacement   Front Driveshaft U-Joint replacement Icon_minitimeTue Feb 20, 2007 10:28 pm
mrjeepy wrote:
Hey Danny...
It must have been something stuck up in the drums. I pressure washed them out real good and the squeaks went away. mbn Freezingaxle syndrome went away too!
The wobbly front ds wreaked havoc on my front pinion seal and its leaking (4 inch round puddle after being parked 9hrs) Thanks to Kat (and Von via phone) I know how to fix that.
onemoretime
onemoretime
Number of posts : 196
Registration date : 2007-01-18
PostSubject: Re: Front Driveshaft U-Joint replacement   Front Driveshaft U-Joint replacement Icon_minitimeWed Feb 21, 2007 12:04 am
I may take your tip on skylar. Also good choice with the DS. For my part i would have gotten rid of the CV(double kardan joint) altogether on it. An ran a standeard drivshaft. I never understood jeep on this one. But it is defienetly not needed on the front. Oh well my .02
https://mrr4x4cforum.editboard.com
PostSubject: Re: Front Driveshaft U-Joint replacement   Front Driveshaft U-Joint replacement Icon_minitimeWed Feb 21, 2007 11:43 am
I picked up the rebuild this morning. Its nice and shiney now... I guess it will just rust like the stock one. If I tried to paint it or put some kind of coating that would throw it out of balance again, right?
PostSubject: Re: Front Driveshaft U-Joint replacement   Front Driveshaft U-Joint replacement Icon_minitimeWed Feb 21, 2007 12:40 pm
I don't think so. The shop down by me puts a fresh coat on everything they do.
MYYJROX
MYYJROX
Number of posts : 738
PostSubject: Re: Front Driveshaft U-Joint replacement   Front Driveshaft U-Joint replacement Icon_minitimeWed Feb 21, 2007 1:05 pm
Danny - call me before you change that seal. I found out something we didn't do that we should have done last time.
ne14jpn
ne14jpn
PostSubject: Re: Front Driveshaft U-Joint replacement   Front Driveshaft U-Joint replacement Icon_minitimeWed Feb 21, 2007 9:42 pm
definately paint er up. won't affect anything except rust prevention!
onemoretime
onemoretime
PostSubject: Re: Front Driveshaft U-Joint replacement   Front Driveshaft U-Joint replacement Icon_minitimeWed Feb 21, 2007 11:38 pm
ya danny paint her up
Chris Taylor
Chris Taylor
Number of posts : 359
PostSubject: Re: Front Driveshaft U-Joint replacement   Front Driveshaft U-Joint replacement Icon_minitimeWed Jun 06, 2007 8:27 pm
I know I am reviving an old post but when I broke my pinion strap bolt I may have banged up the drive shaft. I am having it checked in the morning. My question is how much did this run you to retube it and where you satisfied with A1? I was going wheel'n this weekend so I would like to have this done ASAFP and I looked at new ones and almost crapped myself on the prices. is there a source to find what other years match? I would like to get the one off the 90 XJ 4 door automatic that I got the pinion yoke from if it will match even if it is for a spare.
And does anyone have the #
PostSubject: Re: Front Driveshaft U-Joint replacement   Front Driveshaft U-Joint replacement Icon_minitimeWed Jun 06, 2007 8:30 pm
Retube and Balance normally cost anywhere from 150-200. Thats at my local shop.
PostSubject: Re: Front Driveshaft U-Joint replacement   Front Driveshaft U-Joint replacement Icon_minitimeThu Jun 07, 2007 12:09 am
That price is about right, but they also pressed in 3 new u-joints and reconditioned the ball on the transfer case end of the driveshaft.
It only took one day.
Chris Taylor
Chris Taylor
PostSubject: Re: Front Driveshaft U-Joint replacement   Front Driveshaft U-Joint replacement Icon_minitimeFri Jun 08, 2007 12:20 am
Thanks for the # and address, Danny. I called them and if I drop it off Friday Morning they will have it back to me in a couple of hours. mbn Looks like I will make it to Rausch this week after all.
» Axle / U-joint replacement?
» slip yoke for driveshaft w/ 1350 joint
» Front diff leak and service front end
» johnny joint
» Rear U-joint
