| She blew 4 1/2 times the legal limit. | |
+4MaxRox ne14jpn MYYJROX Rockn93YJ 8 posters |
| Subject: She blew 4 1/2 times the legal limit. Tue Mar 27, 2007 10:03 am | |
| Emissions test Hydrocarbons allowed amount is 220 ppm, she blew 958. Carbon Monoxide allowed is 1.2 pct, she blew 5.62. check engine light was on, I covered that with the CB mike. No cat on my jeep but he couldn't see it anyway due to the extensive skidplating. they wouldn't let the jeep on the treadmill since I had the 35" tires on it and did the idle test at the tailpipe. I have a hole in the Banks header which is under warranty. Air gets in and causes the O2 sensor to trigger a computer response and dump more fuel. It's running really rich because of that and you can smell the unburnt fuel. Since I failed I have 4 months to get it fixed and test again. you may apply for a repair waiver after the vehicle fails the test, is repaired, then fails again. You must spend the minimum amount which I think was just moved up to $450. | |
| Subject: Re: She blew 4 1/2 times the legal limit. Tue Mar 27, 2007 11:17 am | |
| WOW!! Those are some high numbers! Was it that bad the last time you had it tested? | |
ne14jpn LS/Locker
Number of posts : 53 Age : 37 Registration date : 2007-01-21
| Subject: Re: She blew 4 1/2 times the legal limit. Tue Mar 27, 2007 12:31 pm | |
| nice title. hope she sobers up for ya Bill | |
MaxRox Locker/Locker
| Subject: Re: She blew 4 1/2 times the legal limit. Tue Mar 27, 2007 1:39 pm | |
| WOW! Guess it went just as you imagined. Good luck with the repairs! | |
| Subject: Re: She blew 4 1/2 times the legal limit. Tue Mar 27, 2007 3:00 pm | |
| First step is to send the Banks Torquetube header back for a replacement. Also need to install a catylitic converter, check the plugs, wires, cap and rotor etc. | |
| Subject: Re: She blew 4 1/2 times the legal limit. Wed Mar 28, 2007 12:47 pm | |
| good luck bill call me if you when plan on swapping out the banks header. I want to check it out. | |
| Subject: Re: She blew 4 1/2 times the legal limit. Wed Mar 28, 2007 1:28 pm | |
| Add me to that call list too. I have to replace mine eventually & would like to see how it's done so I can do it myself when the time comes. | |
| Subject: Re: She blew 4 1/2 times the legal limit. Wed Mar 28, 2007 6:14 pm | |
| The header should be in today or tomorrow. I will likely change it out this weekend. Also the cat will be in. I will weld that in as far up the pipe under the belly as I can get it this weekend. Plan is to hook up the complete exhaust for testing and then remove the exhaust from the cat back for wheeling. I will cut a pipe to run the exhaust back from the cat and dump it behind the belly pan as it was before. I don't have a time set but will likely get it done this weekend. Sorry for short notice. | |
| Subject: Re: She blew 4 1/2 times the legal limit. Thu Mar 29, 2007 10:35 am | |
| Count me out. Nester & I will both be at Paragon on Saturday & I have a dance recital to go to on Sunday. I have been waiting for someone to do this project so I can see how it's done but Aunt Kathy duty takes precidence over Jeep work. Take some pics as it (and whatever other parts need to come out) comes off of the block & goes back in. Thanx! | |
| Subject: Re: She blew 4 1/2 times the legal limit. Thu Apr 05, 2007 5:42 pm | |
| New exhaust is on. Barely enough room for a cat but it's on there. Right at the bend of the head pipe I cut off everything and cut off the lead pipe to the cat and welded that together, then cut off the lead pipe for the muffler and mounted the muffler right up against the cat. Then ran pipe custum bent and welded around the upper triangulated links and out the stock location. All the check engine lights are off now. time for testing again. | |
| Subject: Re: She blew 4 1/2 times the legal limit. Thu Apr 05, 2007 6:05 pm | |
| Good Luck, Bill! I'll be rootin' for ya! | |
| Subject: Re: She blew 4 1/2 times the legal limit. Thu Apr 05, 2007 7:45 pm | |
| x2. Let us know what she blew this time too. | |
| Subject: Re: She blew 4 1/2 times the legal limit. Tue Apr 10, 2007 12:55 pm | |
| I PASSED!!!!!!!! new spark plugs, new cat and fixed header gasket leak. No more testing until OCT 2008. new readings HC 33PPM, CO .48 PPM | |
| Subject: Re: She blew 4 1/2 times the legal limit. Tue Apr 10, 2007 2:10 pm | |
| Subject: Re: She blew 4 1/2 times the legal limit. Tue Apr 10, 2007 2:12 pm | |
| Congrats! Now we'll all breath better on the trail! | |
4jeepnuts LS/Locker
Number of posts : 52 Age : 60 Localisation : Derry, PA Registration date : 2007-05-02
| Subject: Re: She blew 4 1/2 times the legal limit. Thu May 17, 2007 5:35 pm | |
| Why did I see the title of this thread and think of Paris Hilton | |
| Subject: Re: She blew 4 1/2 times the legal limit. Thu May 17, 2007 8:36 pm | |
| Nice | |
Locked_N_Lovely Open/Open
Number of posts : 8 Age : 41 Localisation : Reading, PA Registration date : 2007-03-09
| Subject: Re: She blew 4 1/2 times the legal limit. Thu May 17, 2007 11:22 pm | |
| Thank god i don't have to go through this...my rig is a pig - stinks like hell | |
| oops thought i was on my name - too lazy to switch | |
| Subject: Re: She blew 4 1/2 times the legal limit. | |
