| 231 transfer case speedometer sending unit | |
| Subject: 231 transfer case speedometer sending unit Fri Aug 21, 2009 9:37 am | |
| Anyone got one they can bring to Rausch on sunday? gotta plug the hole in the transfer case even though I'm not using a speedometer. | |
MonsterS10 Locker/Spool
| Subject: Re: 231 transfer case speedometer sending unit Fri Aug 21, 2009 1:11 pm | |
| Bill get a freeze plug we use block in th race cars this way or use a rubber expasion plug | |
| Subject: Re: 231 transfer case speedometer sending unit Fri Aug 21, 2009 1:26 pm | |
| i will look into that thanks | |
| Subject: Re: 231 transfer case speedometer sending unit Fri Aug 21, 2009 1:41 pm | |
| where do you find the expansion plug? home depot? | |
| Subject: Re: 231 transfer case speedometer sending unit Fri Aug 21, 2009 1:44 pm | |
| bill will a 242 0r 249 plug work? if so I have one or two laying around. | |
| Subject: Re: 231 transfer case speedometer sending unit Fri Aug 21, 2009 2:20 pm | |
| I bought rubber expansion plugs at NAPA a long time ago when I had to get the YJ MD Inspected. They wouldn't pass it bc the drain holes were open. They were like $7 each. | |
| Subject: Re: 231 transfer case speedometer sending unit Fri Aug 21, 2009 2:34 pm | |
- where do you find the expansion plug? home depot?
don't know if you have any ACE hardware stores in your area with good bolt and fastener selection but that would be a good place to check. We have one in our area with stuff like this. | |
| Subject: Re: 231 transfer case speedometer sending unit Fri Aug 21, 2009 3:09 pm | |
| Subject: Re: 231 transfer case speedometer sending unit Fri Aug 21, 2009 3:14 pm | |
| Subject: Re: 231 transfer case speedometer sending unit | |
