 spool and ARB which to go in front and rear?
spool and ARB which to go in front and rear? Empty
PostSubject: spool and ARB which to go in front and rear?   spool and ARB which to go in front and rear? Icon_minitimeTue Jan 12, 2010 6:05 pm
The spool is in the rear and ARB is in front but it's been suggested that i swap the spool to the front and arb to the rear to make steering 100% easier cause the full hydraulic will always turn the front. comments?
MonsterS10
MonsterS10
Number of posts : 267
PostSubject: Re: spool and ARB which to go in front and rear?   spool and ARB which to go in front and rear? Icon_minitimeTue Jan 12, 2010 7:04 pm
Spool in front ARB in rear but they are different from high pinion to low pinion
PostSubject: Re: spool and ARB which to go in front and rear?   spool and ARB which to go in front and rear? Icon_minitimeTue Jan 12, 2010 7:27 pm
I would swap them Bill. If you run the ARB in the rear you can also have effective cutting brakes if you ever install them. Plus ARB's are a head ache and if it goes out you would rather have a locker in the front.
PostSubject: Re: spool and ARB which to go in front and rear?   spool and ARB which to go in front and rear? Icon_minitimeTue Jan 12, 2010 9:27 pm
I would think arb front and rear would be the best do to selectability but I have no faith in arb's.
PostSubject: Re: spool and ARB which to go in front and rear?   spool and ARB which to go in front and rear? Icon_minitimeTue Jan 12, 2010 10:45 pm
well if not interchangable hp to lp then that ends this idea. not going to invest into it. I'll have to see how it does and change later if needed.
» Front track bar
» i like this front clip
» tj front bumper
» rear for a yj
» ADJ. front track bar
