Alright... so everyone knows I have a tendency to "Drive it like I stole it".
I just bent my second set of control arms on the front axle. This time I did not bend the mounts (Rusty's was right... 1/4" thick steel brackets ROCK!!!). One day I will learn if I attempt to climb a fallen tree taller than 1/2 the tire, followed by rocks above my bumper, I may have made a wrong turn....
I landed down on a rock and shifted passenger (see also my Oil Pan Post)... dead center on the side of the driver arm... recovery off almost flopped me onto my passenger side... due to my quick reaction (along with my diet not working to well
) my extra girth leaning out and grabbing the rocker was enough counter weight to keep it shiny side down.
Anyway... I have another set to put on... quick fix... but I had a thought during the drive home... (and no it was not "I shouldn't have done that
Since the stock ones are just an open channel... would it help to get a piece of 1/4" plate steel and weld it across the arm to box it... this might help to stop it from crushing in on itself.
The obvious answer is to upgrade, but at this stage of the build I am not sure which way I am going (high clearance fenders with upgrade arms or lift, and if lift then long or short arm).
I do not want to throw money into heavy duty arms if I can't use them on my future plans...
Just round tabling my thought process to all those who have "been there, done that".
Tony
