| Subject: Re: OBA with the AC compresor Thu Oct 04, 2007 11:06 am | |
- If you got some free time stop on by, I'll be at it most of the sat. Also Grayson do know if any of the local boys have a tube/pipe bender that I could borrow for a couple of hours to make some tube doors?
ok, let me check on the tube bender and ill get back to you. FYI harbor frieght has small tubing benders that you could get a couple good uses out of. | |
| Subject: Re: OBA with the AC compresor Thu Oct 04, 2007 12:10 pm | |
| Called to get a price on a piece of hyrdaulic line (20") with the NPT fittings and i was looking at like $65. I went to harbor freight and got 25' ($12)goodyear hose with the ends already on and used the pressed on 1/4" in the 2 places that normally blew off with a hose clamp. I rerouted all the new line and everything is great with no leaks. I think i'm in good shape now! | |
| Subject: Re: OBA with the AC compresor Thu Oct 04, 2007 11:38 pm | |
| you got to love harbor freight. | |
| Subject: Re: OBA with the AC compresor Sat Oct 06, 2007 8:21 pm | |
| Got the OBA up and running today. It works real good with the 5 gallon tank in the back. I can do a set of lug nuts like its nothing. I also set it up so I can remove or add extra tanks with out no real effort for larger jobs such as using cutting wheels. Right now i just got all the lines jerry rigged so I have to go back tomorow and tighten everything down but i'm real happy with how well the compressor works. | |
| Subject: Re: OBA with the AC compresor | |
