| The Resurection Project | |
+21S h a n e MYYJROX ffhill61 lt.dan jealos-z SPP YJ mdcj7 SLeach Locked_N_Loaded 4jeepnuts The Devil Dog projblacknblue UPNOVER rockdw72 thinga'ma'rig connordanny Grason timberwolf makitupthehardway Rockn93YJ md4wheelin 25 posters |
| Subject: Re: The Resurection Project Fri Apr 17, 2009 11:44 pm | |
| edited: Is he an expert picklepuller or picklelicker, if I was to guess I would say pickleyoupornpuller | |
S h a n e Locker/Locker
Number of posts : 148 Age : 45 Localisation : Woodbine, Maryland Registration date : 2007-11-02
| Subject: Re: The Resurection Project Sat Apr 18, 2009 3:42 pm | |
| you have less then a week, get all your jokes in because im going elbow deep when you sleep | |
| Subject: Re: The Resurection Project Sat Apr 18, 2009 9:44 pm | |
| not if I blow it off with some fireworks first | |
| Subject: Re: The Resurection Project Sat Apr 18, 2009 9:46 pm | |
| Also I got the rear 60 fully installed today except for the drive shaft. I had some old shocks of matts that were for jeeps with 4" of lift and its to big. some I'm guessing i could almost get away with a stock jeep shock or something a little bigger. | |
| Subject: Re: The Resurection Project Sun Apr 19, 2009 7:30 pm | |
| Well god damn joe your not far away from the 30 page mark. Maybe then we can slow this thing down a little more so you can get a 40 page mark. | |
Number of posts : 604 Age : 51 Localisation : Bloomsburg PA Emploi : Mechanic Registration date : 2007-09-17
| Subject: Re: The Resurection Project Sun Apr 19, 2009 9:00 pm | |
| Subject: Re: The Resurection Project Sun Apr 19, 2009 9:09 pm | |
| i don't think i'll have any probs with hitting the forty mark. I have a few more things that i want done that will take up some space.
swap in the 4.10 gears I have. rear winch bumper rear tube fenders front suck down winch finish installing hydro assist atlas tc case so I can get the cutting brakes. upgrade rear 60 to 35 spline upgrade front 60 outers to 35 spline decent driveshafts fix taillights and add side veiw mirrors to mke it street leagal again new seats also wheel the piss out of it. | |
| Subject: Re: The Resurection Project Sun Apr 19, 2009 9:14 pm | |
| Subject: Re: The Resurection Project Mon Apr 20, 2009 11:27 pm | |
| Heres some pics of the finished rear 60 A pic of DD looking at me like what the hell am i doing now. also picked up some steel for the tie rod at 3/8" thick I don't think that it will be bending from rocks or the ram | |
| Subject: Re: The Resurection Project Wed Apr 22, 2009 6:30 pm | |
| Joe, I got your message give me a call. link to kingpin and steering arm assembly https://s257.photobucket.com/albums/hh221/rockn93yj/CJ7%20Project/Kingpin%20rebuild/?start=0 | |
| Subject: Re: The Resurection Project Thu Apr 23, 2009 10:56 pm | |
| yep mine (ballistic) are totaly different, there all one piece with no spring. | |
| Subject: Re: The Resurection Project Fri Apr 24, 2009 8:38 am | |
| Damn Joe I knew you could do it. 30 pages. | |
| Subject: Re: The Resurection Project Sun May 24, 2009 9:55 pm | |
| been a little bit since i've updated but worke has picked up so i've been working as much as I can before it slows up for the summer. Anyway I ve been getting a few small things done but i finally got around to installing the psc pump and did a test run on the ram. Every seems to work great, so I'm guessing i tapped the box in the right spot. Anyway to take care of the cooling for the hydro assist, I rigged up an old tranny cooler i had. I'm waiting for a small fan to come in that I ordered from summit that will be bolted to that and wired to a switch. | |
| Subject: Re: The Resurection Project Sun May 24, 2009 10:14 pm | |
| Glad to see you went with the good stuff. now when I order mine you can help with the plumbing and tapping the steering box. | |
| Subject: Re: The Resurection Project Sun May 24, 2009 10:36 pm | |
| Good idea with the cooler, i am full hydro and ran one like that and it was cool to the touch. | |
| Subject: Re: The Resurection Project Mon May 25, 2009 10:40 pm | |
| Subject: Re: The Resurection Project Tue May 26, 2009 7:49 am | |
| Don't know how you get away without hitting the pitman arm. On the CJ I'm putting the tie rod behind the axle to avoild hitting anything. We'll see how that goes. I had to move my track bar up on the YJ due to hitting, built a new bracket that went tight up against the frame on the inner side i believe. | |
| Subject: Re: The Resurection Project Tue May 26, 2009 10:51 am | |
| I have plenty of clearence on the pitman and even clear the oil pan. Only funny thing is that another guy with the same set up except for the 40" ltbs but and clayton long arms has probs with the truss hitting the oil pan on his zj. | |
| Subject: Re: The Resurection Project Tue May 26, 2009 2:19 pm | |
| is that a solid bar you used to extend the link? where did you obtain such a thing? | |
| Subject: Re: The Resurection Project Tue May 26, 2009 3:44 pm | |
- is that a solid bar you used to extend the link? where did you obtain such a thing?
yes, from the back of my container We orginally purchased it to make pins for a dump truck but decided to use something else. As for the steel you can get what ever size/shape you want from the steel stores around here. I use metal express but there are a few closer your way I think. | |
| Subject: Re: The Resurection Project Mon Jun 01, 2009 12:22 am | |
| Subject: Re: The Resurection Project Sat Jun 13, 2009 4:11 pm | |
| Come on now you should be workin on This thing Now so you dont have to rush for Sept Big Dogs | |
| Subject: Re: The Resurection Project Sun Jun 14, 2009 12:37 am | |
| No, Rob dont you know Jow does his best work in the last 5 days before a big dogs event. | |
| Subject: Re: The Resurection Project Sun Jun 14, 2009 9:01 pm | |
| nester you hit that right on the head. To be honest I haven't even pulled it off the trailer yet from big dogs. I'll probley begin to lay into it this week to get it ready to tear it back down again. Usally after an event i'm so sick of the damn thing I don't even want to look at it. I'm hoping to have it ready for the jeep show but the dead line is the end of july when I'm supposed to head out to harlan with a bunch of other grocey getters including the guys from trucks with the zj they built. The to do list as of now 1. weld on new J.J. to lower CA 2. re weld up new UCA 3. install new hydro lines 4. retain lower part of front coils 5. retain upper rear coils 6. rear bump stops 7. new rear shocks 8. instal 4.10 gears 9. weld up rear 10. install yj pitman 11. figure out what to do with front track bar bracket. 12. some wiring issues 13. figure out why motor runs ruff at an idel sometimes. I'm sure there's alot more that i'll find once i knock the dirt off and begin to tear it down once again. | |
| Subject: Re: The Resurection Project Sun Jun 14, 2009 9:40 pm | |
- end of july when I'm supposed to head out to harlan with a bunch of other grocey getters including the guys from trucks with the zj they built.
Oh ok so you are not even going to invite us huh.... | |
| Subject: Re: The Resurection Project | |
