| Subject: Bought at 8.8 Wed Jan 30, 2008 9:47 am | |
| Here are the details from Ebay. I got it for $100. I know it will need to be regeared but does the rest look ok? I am a complete idiot when it comes to axles.....
Up for auction is a 1989 lincoln disc brake rear end. I recently removed this item from a car that ran and drove. The stud pattern is a 4.5 bolt pattern. It has ABS. Here are the tag numbers from the rear: S407F 3L27N889D18. Ford told me that the numbers come up as an 8.8 with 327 limited slip gear ratio. Rear end cover is a 10 bolt cover. It is 44.75 inches from outside to outside shock mounts. It is 54.25 inches from backing plate to backing plate. It is 45 inches from outside to outside lower control arm mounts. One wheel stud is broke on the driver's side. There are no rotors or calipers included. | |
| Subject: Re: Bought at 8.8 Wed Jan 30, 2008 9:54 am | |
| I hate to tell you this but I think the spline count is low on those axels because its out of a car which makes it no better then a d35. Thats the reason you need to stick with a 95 or newer 8.8 because they have the 31 spline count and disk brakes. | |
| Subject: Re: Bought at 8.8 Thu Jan 31, 2008 12:17 am | |
| I have an empty housing that I plan to scrap but no axles, brakes, or guts hurry up if you want it | |
| Subject: Re: Bought at 8.8 Thu Jan 31, 2008 2:53 pm | |
- I hate to tell you this but I think the spline count is low on those axels because its out of a car which makes it no better then a d35. Thats the reason you need to stick with a 95 or newer 8.8 because they have the 31 spline count and disk brakes.
S&^t Should have done research before I bid.... Oh well the search continues.... | |
| Subject: Re: Bought at 8.8 Thu Jan 31, 2008 5:59 pm | |
| Did you buy it or did you contact the seller to call it off. | |
| Subject: Re: Bought at 8.8 Fri Feb 01, 2008 10:57 am | |
| No I bought it cause when I saw it on ebay the bidding was almost over. I am supposed to pick it up tonight but I have the flu so I will get it next week. | |
| Subject: Re: Bought at 8.8 | |
