| Subject: Re: Project "Mud Bandit" dedicated mud bogger Fri Jul 31, 2009 4:11 pm | |
| - SPP YJ wrote:
- After looking at the RC Specs I dont know why they waht a roof or gas tank protection.
With a full cage and seats and 5 points why a roof?
with a good fuel cell like the one you have why a fire wall around tank? I know, it is a lot of excess work that i don't believe needs to be done but I think it is all in the name of safety and taking every precaution they can to make sure nowbody gets hurt with the higher speed and higher risk races. roof to keep the hands inside the vehicle and prevent broken fingers or if there is a gas leak and a fire and fuel running on the ground burning at least there is a roof to protect you. fuel cells can develop leaks no matter how well they are constructed. could get a hole worn in the tank from it coming loose and slowly wearing a hole in it and suddenly there is no protection from a fire. really bites with all the extra work but got to be safe. After buying the used axle i can see how people think they are fabricators and really screw things up. | |
| Subject: Re: Project "Mud Bandit" dedicated mud bogger Sun Aug 02, 2009 9:26 pm | |
| OK radiator is moved to the back of the jeep. It took some really creative tube bending to get it routed under the jeep. Didn't plan ahead and put a body lift on, that would have been too easy. I still need to pick up 4 pieces of 6" radiator hose to finish it up. | |
| Subject: Re: Project "Mud Bandit" dedicated mud bogger Mon Aug 03, 2009 8:15 am | |
| got pics? like to see your work | |
| Subject: Re: Project "Mud Bandit" dedicated mud bogger Mon Aug 03, 2009 9:00 am | |
| its coming, i was so tired yesterday and still sweating a storm from all the welding and wearing the welding suit to prevent any more burns that i just jumped in the pool with casey and called it a day. | |
| Subject: Re: Project "Mud Bandit" dedicated mud bogger Tue Aug 04, 2009 9:55 pm | |
| remote battery kit came in today along with the windshield hinges. shame i can't work on it till i get back from the beach. | |
| Subject: Re: Project "Mud Bandit" dedicated mud bogger Fri Aug 07, 2009 9:58 am | |
| List to get running for the test run on the 23rd. Install battery relocation kit Install radiator and hose links and fill system wire radiator thermostat controlls install seat belt tabs install bump stops secure brake lines and bleed brakes plug NP231 sending unit hole and fill with fluid adjust steering and install cotter pins fix rear u joint (misaligned on pin) Wire fuel pump wire temp guage route spark plug wires from headers install vents (axles, tranny, tcase, radiator overflow). FIRE IT UP with fingers crossed. | |
| Subject: Re: Project "Mud Bandit" dedicated mud bogger Fri Aug 07, 2009 1:38 pm | |
| One week. But I have faith | |
| Subject: Re: Project "Mud Bandit" dedicated mud bogger Tue Aug 18, 2009 9:52 pm | |
| mounted the remote battery kit and rewired all the engine grounds and winch cables while i was at it. take 3 steps forward and 2 steps back with all the rewiring that needed done. Example there was a ground wire running from the front grill for the lights that went back to the valve cover bolt and then back to the fiberglass firewall and then down to the transmission mounting bolt. | |
| Subject: Re: Project "Mud Bandit" dedicated mud bogger Wed Aug 19, 2009 10:06 am | |
| Going to refocus my attention to making this a dedicated mud bogger. Was aiming towards rock racing since it would be a blast to open this thing up at Rausch but trying to make it a jack of all trades and master of none is senseless. Frees up a lot of time to make this thing run really well in the mud. | |
| Subject: Re: Project "Mud Bandit" dedicated mud bogger Wed Aug 19, 2009 10:51 am | |
- Going to refocus my attention to making this a dedicated mud bogger. Was aiming towards rock racing since it would be a blast to open this thing up at Rausch but trying to make it a jack of all trades and master of none is senseless. Frees up a lot of time to make this thing run really well in the mud.
Good move. I'm sure that rock racing would be a blast but its would be super hard to be competative with guys and rigs that all they want to do is rock race. Plus the mud bog is close to the house. | |
| Subject: Re: Project "Mud Bandit" dedicated mud bogger Wed Aug 19, 2009 11:49 am | |
| It would be fun to do the rock race but expensive to build the jeep to that level to be competitive and a big investment for a couple of fun runs. I feel better having made that decision and it does free up a lot of time that i could spend wheeling.
Mud bogs: Frog eye mud bog is under 10 miles. Kingsdale Mud bog is about an hour. Then there is Big Dogs. Rausch Creek is starting one as well. | |
| Subject: Re: Project "Mud Bandit" dedicated mud bogger Fri Aug 21, 2009 9:26 am | |
| Install battery relocation kit - DONE Install air relief valve for radiator hose - DONE Install radiator and hose links - DONE Install rear tow points - DONE Pick up Full soft doors - DONE
install seat belt tabs - IN PROGRESS
wire radiator thermostat controlls install bump stops secure brake lines and bleed brakes plug NP231 sending unit hole and fill with fluid adjust steering and install cotter pins fix rear u joint (misaligned on pin) Wire fuel pump wire temp guage route spark plug wires from headers install vents (axles, tranny, tcase, radiator overflow). | |
| Subject: Re: Project "Mud Bandit" dedicated mud bogger Fri Aug 21, 2009 11:31 am | |
| Getting closer good luck hope to see it Sunday morning. | |
| Subject: Re: Project "Mud Bandit" dedicated mud bogger Fri Aug 21, 2009 12:35 pm | |
| I'll be up there for sure, not too sure it will be the CJ though. Oh yeah did I mention my ARB isn't working again. Blowing air out the axle vent so probably time for a seal replacement again. I'm starting to think about buying a spool. | |
| Subject: Re: Project "Mud Bandit" dedicated mud bogger Fri Aug 21, 2009 2:15 pm | |
| Sorry guys but I have to say it ARB's suck | |
| Subject: Re: Project "Mud Bandit" dedicated mud bogger Mon Aug 24, 2009 9:44 am | |
| install seat belt tabs - DONE Wire fuel pump - DONE wire temp guage - DONE wire radiator thermostat controlls - DONE route spark plug wires from headers - DONE install vents (axles, tranny, tcase, radiator overflow). - DONE
install bump stops secure brake lines and bleed brakes plug NP231 sending unit hole and fill with fluid adjust steering and install cotter pins fix rear u joint (misaligned on pin) Replace starter/solenoid(bench test first) | |
| Subject: Re: Project "Mud Bandit" dedicated mud bogger Mon Aug 24, 2009 11:34 pm | |
| picked up a new starter/solonoid today. Will try it out tomorrow again and hopefully have good news. bell housing cover was not a factor. | |
| Subject: Re: Project "Mud Bandit" dedicated mud bogger Tue Aug 25, 2009 6:26 pm | |
| If you need a hand finishing stuff up saturday let me know. | |
| Subject: Re: Project "Mud Bandit" dedicated mud bogger Tue Aug 25, 2009 9:09 pm | |
| I just might. Spent the evening trying to figure out this no start situation. tried charging the battery and turned the key, faster clicking. tried jump starting with another battery, fast clicking. tried grounding directly to the starter and touching the + cable to the terminal on the solenoid and just fast clicking. Not sure whats going on now. the new starter works with no load, i tested it before I put it in. Tomorrow it is going to the professionals and we'll see what they find. | |
| Subject: Re: Project "Mud Bandit" dedicated mud bogger Tue Aug 25, 2009 9:13 pm | |
| Can you turn motor over by hand? | |
| Subject: Re: Project "Mud Bandit" dedicated mud bogger Tue Aug 25, 2009 9:15 pm | |
| Does the starter need shimed at all you could try just loosing it a little and see if it cranks if it does you will need a shim not all that uncommon. | |
| Subject: Re: Project "Mud Bandit" dedicated mud bogger Tue Aug 25, 2009 9:17 pm | |
| i thought of that too. loosened it up a little and tried it and clicking. then loosened it up more and clicking. I climbed under it to see whats going on and had aaron try to start it and it is turning the flywheel very slightly with each click but no start. | |
| Subject: Re: Project "Mud Bandit" dedicated mud bogger Tue Aug 25, 2009 9:23 pm | |
| funny how big it is compared to the excursion. | |
| sounds to me that the solenoid is not pushing the gear out all the way. when the gear is pushed out there is a electrical contact that makes up and puts power from the big term on starter to motor if that does not make up in solenoid the starter tries to spin from the small start wire and that dint work so well like trying to run a winch off of speaker wire. | |
