| Help me find gears | |
| Subject: Help me find gears Tue Jul 01, 2008 4:07 pm | |
| So I'm looking for a Dana44 Ring and Pinion for a HP 44 out of a 78-79 F-250. If anyone has a lead on one for cheap please let me know. If not I'm going to order a new set by next monday. | |
| Subject: Re: Help me find gears Tue Jul 01, 2008 7:44 pm | |
| Subject: Re: Help me find gears Wed Jul 02, 2008 2:19 pm | |
| How did I miss that one. I need 4:10's | |
| Subject: Re: Help me find gears Thu Jul 03, 2008 11:37 am | |
| i think you are in luck, i pull the 4.10 gears with carrier out of the ford hp d44 axles in my jeep when i put my 5.13's in. i will check for them. i also had the d 60 r+p from the rear with carrier | |
| Subject: Re: Help me find gears Mon Jul 07, 2008 8:30 pm | |
| Hey Von let me know if you found them. | |
| Subject: Re: Help me find gears Tue Jul 08, 2008 7:26 am | |
| i found them, now to find the ratio, i count the ring gear teeth and divide the pinion teeth into it. is that right | |
| Subject: Re: Help me find gears Tue Jul 08, 2008 8:40 am | |
| That is correct. if you don't feeel like calculating here is a calculator to just plug in the numbers. What is the ratio on the D60? http://www.4lo.com/calc/gearring.htm | |
| Subject: Re: Help me find gears Tue Jul 08, 2008 12:56 pm | |
| i will find out, the d60 has clutches in the carrier. so it is probably a limited slip | |
| Subject: Re: Help me find gears Wed Jul 09, 2008 10:36 pm | |
| any luck Von?
Bill if you want the 60 gears that Von has I can pick them up for you. | |
| Subject: Re: Help me find gears Wed Jul 09, 2008 10:41 pm | |
| IF they are stock gears they are prob 4.10 gears. I think I may pass on them until I see how this thing runs without the gear change. | |
| Subject: Re: Help me find gears Sun Jul 20, 2008 8:08 pm | |
| yes they are 4.10 gears.i have the carrier with the spidergears and r+p. and the d60 parts as well..... when did you want to get them.... you guys can have them for the low low price of $0000. i know if you all had something i needed you would help me out. | |
| Subject: Re: Help me find gears Sun Jul 20, 2008 9:39 pm | |
| Hey Von when could I come get them. I need them ASAP. PM me a address, phone number and when is a good time. I will grab the set for Bill in case he needs it. | |
| Subject: Re: Help me find gears Mon Jul 21, 2008 8:45 am | |
| they are in my garage at my house. i will mark them and put them right inside of the smaller side entry door next to my garage door. i do not know what times are good for you but i will leave my garage door unlocked for you. if i am not there. i will pm you back, thanks. maybee you can check the buggy out while you are there | |
| Subject: Re: Help me find gears Mon Jul 21, 2008 8:39 pm | |
| Von I will call your cell phone asap. | |
| Subject: Re: Help me find gears | |
