| busted bolt removal help needed | |
| Subject: busted bolt removal help needed Sun Jan 24, 2010 12:42 pm | |
| found a broken bolt in the th400 to 203 adaptor. I tried welding a nut on for removal twice and failed. tried drilling and failed. This is a hardened steel bolt that has been there since 1979. Ideas? | |
| Subject: Re: busted bolt removal help needed Sun Jan 24, 2010 1:28 pm | |
| That looks like the crossmember mount. is it needed? The doubler has a mount doesn't it? | |
| Subject: Re: busted bolt removal help needed Sun Jan 24, 2010 1:37 pm | |
| never mind just looked at pics. is there enough there to get vise grips on. heat the case and not the bolt and see if it will break free. it looks like its in there pretty good drilling it out might be the only way
| Subject: Re: busted bolt removal help needed Sun Jan 24, 2010 1:38 pm | |
- That looks like the crossmember mount. is it needed? The doubler has a mount doesn't it?
Yes needed. It actually has the bolt pattern for the tranny and 203 on it. Bolt 6 circle pattern onto tranny and then bolt 203 onto the adaptor. The 203 wont bolt directly to the tranny without it. Got this interesting chart from the creeps. Some of you might appreciate this. Machinist's Workshop magazine tested penetrants for break out torque on rusted nuts. They are below, as forwarded by an ex-student and professional machinist, Bud Baker. They arranged a subjective test of all the popular penetrants with the control being the torque required to remove the nut from a "scientifically rusted" environment. Penetrating oil ..... Average load None ...................... 516 pounds WD-40 ................... 238 pounds PB Blaster ............... 214 pounds Liquid Wrench ......... 127 pounds Kano Kroil .............. 106 pounds ATF-Acetone mix.......53 pounds The ATF-Acetone mix was a "home brew" mix of 50 - 50 automatic transmission fluid and acetone. Note the "home brew" was better than any commercial product in this one particular test. Our local machinist group mixed up a batch and we all now use it with equally good results. Note also that "Liquid Wrench" is about as good as "Kroil" for about 20% of the price. | |
| Subject: Re: busted bolt removal help needed Sun Jan 24, 2010 1:40 pm | |
| got some additional advise.
1. heat broken bolt red hot 2. weld another 3/4 nut onto broken bolt 3. apply acetone/atf to other side of bolt 4. let cool 5. heat adaptor to expand it off the bolt 6. try to remove again. | |
| Subject: Re: busted bolt removal help needed Sun Jan 24, 2010 2:38 pm | |
| Subject: Re: busted bolt removal help needed Sun Jan 24, 2010 8:58 pm | |
| use snap on easy out with heat and liquid wrench. | |
Hunt Locker/Locker
Number of posts : 121 Age : 42 Registration date : 2009-04-05
| Subject: Re: busted bolt removal help needed Sun Jan 24, 2010 9:04 pm | |
| It blows my mind that the average mechanic does not own a set of left handed drill bits. They are really not that expensive for a basic set and they really are worth there weight in gold. Its one of those "have the right tool for the job and it will pay for it's self the first time you use it" kind of things.
I got my journeyman's license in the Newport News Shipyards and learned very quickly how to remove seawater encrust bolts out of ships equipment.
My recommendation: Often time the simplest method is the best
Penetrating oil Vice grips
If there is an edge you can work with a chisel and hammer some times you can actually walk the stud out
If not:
Penetrating oil Grind head flat Prick punch Center punch Drill
Two things "USUALLY" or "SHOULD" happen. 1. If you can drill it just right you should be able to drill it to the crest of the hole threads and use a scribe to collapse the shell of the bolt. 2. During the drilling process the stud will walk its self out
For the really stubborn ones we had a portable EDM machine that was bad ass.
I just want to be perfectly clear that I am not bagging on anyone. People seem to get butt hurt whenever I post.[left] | |
| Subject: Re: busted bolt removal help needed Sun Jan 24, 2010 9:09 pm | |
| i didn't even know about left handed drill bits till a guy at work showed them to me. I thought it was a joke like a metric adjustible wrench at first. They are pretty nice to have around. | |
| Subject: Re: busted bolt removal help needed Tue Jan 26, 2010 12:57 am | |
| bill you jinkzed me. i went to take my tire off today and rounded off a lug nut. So I welded an old socket to it and hit with the air gun again. this time the lug nut broke off below the welds just were it starts to recess into the wheel. So now I really don't have to much of the lug nut left to mess with. So should i just try to drill out the wheel stud till i'm able to break it off? | |
| Subject: Re: busted bolt removal help needed Tue Jan 26, 2010 9:22 am | |
| Subject: Re: busted bolt removal help needed Tue Jan 26, 2010 9:56 am | |
| i know, f'ed up part is non of those lug nuts went on hard like it was cross threaded. So i don't know why it don't want to come off. | |
| Subject: Re: busted bolt removal help needed Tue Jan 26, 2010 9:59 am | |
| take the other lugs off and see if the tiny piece left will break off when you pull on the opposite end of the tire? | |
| Subject: Re: busted bolt removal help needed Tue Jan 26, 2010 3:40 pm | |
| na, shes solid its probly 3/8" or more of nut left | |
MonsterS10 Locker/Spool
| Subject: Re: busted bolt removal help needed Wed Jan 27, 2010 9:20 am | |
| Sometimes a pointed air chisel will spin them loose we have that problem with those stupid locking nuts all the time if not get the smoke wrench out | |
| Subject: Re: busted bolt removal help needed | |
