| Subject: Tighten those bolts again! Mon Aug 06, 2007 9:27 am | |
| Just a reminder to those that have installed that new lift kit or off road accesssory in the last 6 months. Even after torqued to specs the bolts will work their way loose especially if you didn't use locktite. I've seen pitman arms, control arm bolts, track bar bolts etc come loose on their own over the years of wheeling. This past weekend I went over the jeep again since I will be driving it on the road in NC at jeeps on the beach and did all my fluid changes, lubed all the joints and driveshafts and put a socket on all suspension bolts. all of the suspension bolts were tight except the one on the torque arm. The torque arm nut could be turned by hand but looked ok on visual inspection. I had a very small barely perceivable "thump" with braking that got me thinking about mounting hardware and decided to go over everything. Yes the "thump" did go away after tightening it back down. | |
| Subject: Re: Tighten those bolts again! Mon Aug 06, 2007 10:47 am | |
| Good post. I noticed yesterday while pulling the draglink off that a nut on the passenger control arm was MISSING.... I should have done this a week ago. | |
| Subject: Re: Tighten those bolts again! Mon Aug 06, 2007 1:16 pm | |
| I had bolt disapear on a trail ride some how. thanks to bill we found a bolt that would work. but it had already caused a whole bunch of other damage, ever since I always check everything about once a month. and carry some extra bolts | |
| Subject: Re: Tighten those bolts again! | |
