 finding gear ratios
FallstonYJ
Open/Locker
Open/Locker
FallstonYJ
Number of posts : 45
Registration date : 2008-04-07
finding gear ratios Empty
PostSubject: finding gear ratios   finding gear ratios Icon_minitimeWed May 21, 2008 1:36 pm
Ok, I know this is a stupid question but here it is anyway! I am trying to figure out what gears are in my 88 YJ. I know the stock ratio is 3.07 but I don't know if the previous owner changed gears. I found a method online that says to turn the rear drive shaft and count the shaft revolutions compared to the revolutions of the wheel. Problem is that when I do that the drive shaft turns approx. 1.7 times for one complete revolution of the wheel. From the charts that I have seen that doesn't add up. I am sure I am probably doing something incorrectly but I can't figure it out. Any help would be appreciated. Thanks, Tom.
PostSubject: Re: finding gear ratios   finding gear ratios Icon_minitimeWed May 21, 2008 5:52 pm
when you spin the rear tire is one or both tires off the ground? I believe you have to have just one tire up.
FallstonYJ
Open/Locker
Open/Locker
FallstonYJ
PostSubject: Re: finding gear ratios   finding gear ratios Icon_minitimeWed May 21, 2008 6:34 pm
The whole Jeep is off the ground. I have all the tires off and the Jeep is up on 4 jack stands as I am in the process of putting a 4" suspension lift and a 1" body lift on. If it is true that one wheel has to be on the ground I guess I will have to wait until I am finished with the lifts.
The Devil Dog
The Devil Dog
Number of posts : 1306
Emploi : New Suzuki and Used Car Sales
PostSubject: Re: finding gear ratios   finding gear ratios Icon_minitimeWed May 21, 2008 6:51 pm
Make sure you have the right size tires 217 size tire, if you have bigger tires it will through out your count too.
http://www.myspace.com/tico_mrr
PostSubject: Re: finding gear ratios   finding gear ratios Icon_minitimeWed May 21, 2008 7:26 pm
Yeah if you spin one side and both wheels are off the ground then the pinion yoke will spin but so will the opposite tire but in the opposite direction if unlocked. That will throw off the count.
Number of posts : 438
PostSubject: Re: finding gear ratios   finding gear ratios Icon_minitimeWed May 21, 2008 8:49 pm
with a open rear you just doubble what you turned and it will give the 3:07 your looking for. if you want to know fro sure pull the diff cover and count the teeth or watch the ring gear go around once with the number of turns of the drive shaft.
finding gear ratios
» Help finding a tow rig...
» Problems finding the MeetUp?
» YJ will not go in gear
» Gear & t-case lube?'s
» JK gear packages
