 Juggy race preparation
Juggy race preparation Empty
PostSubject: Juggy race preparation   Juggy race preparation Icon_minitimeMon Aug 22, 2011 9:57 am
Juggy ran GREAT for the shakedown run. Just a few things to fix to be ready for the race, nothing major. Special thanks to Chris Riley for all his hard work getting the Juggy ready for the race. Nick, Chris and Chris let me know if I missed anything please.
Remove driveshafts for repair/to make spares
Order Spare driveshafts
Fill nitrogen tank - Done
Order fuel cans
Buy spare radiator fan
Install stinger bars
Door panels & fix body damage
Replace PSC pump
Fix GPS mount/install
Fix numbers
Lube seat belts & window nets
Charge Intercom
Gopro cage mount
Move air bumps
Fuel vent cutoff
Move tranny mount to avoid driveshaft
Charge bumps and shocks
Drivers rear axleshaft bolts-tack weld
Install-Tranny Cooler
Fix rear diff leak
Cut off old belly pan mounts
Locktite Jam nuts on all links
Locktite steering shaft mount nut
Locktite front hub cover bolts(they are loose)
big94GMC
big94GMC
Number of posts : 140
Registration date : 2010-04-26
PostSubject: Re: Juggy race preparation   Juggy race preparation Icon_minitimeMon Aug 22, 2011 3:09 pm
Did you want to look any further into the backfiring/running rough issue? Or, is that a none issue?
http://www.virginiakrawlers.com/forums/index.php
PostSubject: Re: Juggy race preparation   Juggy race preparation Icon_minitimeMon Aug 22, 2011 9:32 pm
I talked to the engine builder and when he tuned the motor he left it a little fat due to the absence of the proper tools. He said once we do the dyno tune the problem will be resolved. Said better to leave it a little fat than to run a lean motor and destroy parts.
PostSubject: Re: Juggy race preparation   Juggy race preparation Icon_minitimeFri Aug 26, 2011 7:37 am
Spent all day Thursday working on the Juggy. Got a lot done but sill have some work to do. Thanks you Chris Rufner for your help yesterday.
PostSubject: Re: Juggy race preparation   Juggy race preparation Icon_minitimeMon Aug 29, 2011 10:39 am
Updated list. Nick let me know if I missed anything.
Fix GPS mount-
Fire extinguisher-charge
New tranny cooler: CBR-3598DP 16" 14" 8-1/2" -10 O-Ring 12" SPAL Dual
Wrap exhaust and tranny lines
Fix ram mount, ram ends, hose end
Winch cable repair x 2
Front and rear bumpers- no higher than 30"
Mechanical temp gauge 160-280
Spare driveshafts & bearing
Part numbers to build myself
Return PSC pump for rebuild(call for process)
Order fuel cans
Fuel vent cutoff (take to Lowes)
Install stinger bars, paint
Fix diff leaks
Route tranny vent?
PostSubject: Re: Juggy race preparation   Juggy race preparation Icon_minitimeMon Aug 29, 2011 3:05 pm
now that trans cooler is more like it.
PostSubject: Re: Juggy race preparation   Juggy race preparation Icon_minitimeMon Aug 29, 2011 6:17 pm
I ordered the B&M cooler before Miller told me about it. Looks like i've got a spare now for something.
big94GMC
big94GMC
PostSubject: Re: Juggy race preparation   Juggy race preparation Icon_minitimeWed Aug 31, 2011 6:32 pm
The trans cooler that you installed last Thursday did not do the trick??
PostSubject: Re: Juggy race preparation   Juggy race preparation Icon_minitimeWed Aug 31, 2011 8:01 pm
Nope. Made no difference. New cooler is here, big double pass cooler. Chris Riley is fixing the steering and is going to wrap the tranny lines and exhaust with the heat resistant tape. I'm heading up Saturday morning with the new cooler. Plan is to install the new cooler, run the snot out of it to see if it will overheat or not. If it does then it probably needs a different torque converter and may need the "engine braking" feature of the throttle body disabled.
» Juggy phase 2?
» Juggy 2012
» "TEAM JUGGY" Gear!!
» new race in Maryland
» race prep
