Here is the problem, at speeds over 35 mph the front end will wobble and shake till you slow to less that 30 mph. Every once in a while it will not be so bad and let you get to 50 and smooth out.
This started about 2 months ago and a very mild shake between 35 and 40. After the last run at Rausch it was fine until about 15 miles from home and then started with its current state.
What I have done.
1. Rotated front tires to rear to eliminate the possibility of a broken belt
2. thought it was the ball joints so I took it to Matt and had him give it the once over. Said ball joints were tight and the outer tie rod and passenger hub and bearing Assembly was bad
3. Replaced Hub / bearing assembly and outer tie rod, while I had it off I replaced the steering stabilizer also.
4. Replaced broken pinion yoke and reinstalled the front drive shaft.
The shake was going on with the drive shaft off so I don't think I bent it when I broke the yoke. I guess it is possible that the belts in all 4 tires are bad or that it was one in the back and one in the front but I find that hard to believe. It definitely needs new tires but..... $$$ is not there for that yet unless I can find a good used set or something along those lines.
I have to be missing something, throw out the suggestions, I am willing to try just about anything at this point.
