 The Resurection Project
+21
S h a n e
MYYJROX
ffhill61
lt.dan
jealos-z
SPP YJ
SLeach
4jeepnuts
The Devil Dog
projblacknblue
UPNOVER
Grason
timberwolf
25 posters
Go to page : Previous  1 ... 9 ... 14, 15, 16 ... 19 ... 24  Next
The Resurection Project - Page 15 Empty
PostSubject: Re: The Resurection Project   The Resurection Project - Page 15 Icon_minitimeFri Feb 13, 2009 2:45 pm
maybe I said that wrong. I mean should I go with the 3 link setup or just keep the stock configuration. if I 3 link it I would only have to fab one mount point on the RE front Xmember then build the axel with a few prefabbed brackets. Or go with a fabricated or purchased truss plus brackets to make the stock configuration work. No leaf springs. So I guess the corect question is 3 link or 4 link with a small budget in mind.
Bill on pirate and google there were a couple nice write ups on doing your own hydro assist. The box is as simple as drilling two holes in the right spot. I finally found some good picks of the exact location.
PostSubject: Re: The Resurection Project   The Resurection Project - Page 15 Icon_minitimeFri Feb 13, 2009 2:52 pm
also I saw a guy build a nice truss out of 6x3 box that looked just like tnt that i thought about doing but I would need a plasma cutter to make those kind of cuts. I think he traced the the axel out in cardboard then transfered it over the steel to cut. Now that I think about it, maybe I should just give it a try and see how it turns out. If that fails i'm only out of $50 worth of steel and i'll just 3 link it. This way I could get started on it and not have to wait for more funds.
PostSubject: Re: The Resurection Project   The Resurection Project - Page 15 Icon_minitimeFri Feb 13, 2009 3:10 pm
not sure of the stock configuration on the grand. If you need the plasma cutter just let me know.
PostSubject: Re: The Resurection Project   The Resurection Project - Page 15 Icon_minitimeFri Feb 13, 2009 6:27 pm
ah 10-4. If you do the upper link on the drivers side make sure you double check drive shaft clearences. I learned the hard way and had to re-do mine. I have often thought if I had to do it again, put it on the passenger side because the only thing over there is the exhaust.
PostSubject: Re: The Resurection Project   The Resurection Project - Page 15 Icon_minitimeFri Feb 13, 2009 7:50 pm
are you talking about the front axel or the rear matt? i would have to go pass side on mine due to the front diff. Bill The zj have the same front setup as the xj and tj. For the plasma I know your using yours on your project. i can just wait till Grason finishes up with his.
PostSubject: Re: The Resurection Project   The Resurection Project - Page 15 Icon_minitimeFri Feb 13, 2009 9:00 pm
I am talking about the front, but you know now that I think about it I can't remember seeing any xj/zj with the upper link on the same side as diff. but most of everything else has it on the driver side. must be something about the unibody jocolor
PostSubject: Re: The Resurection Project   The Resurection Project - Page 15 Icon_minitimeTue Feb 17, 2009 11:50 am
must be, when I was searching thru buid threads I actualy came across one xj who had it on the drivers side but it looked like it was welded to the cast diff cover which I thought was a bad thing.
After many hours of searching and getting yelled at by mandy for paying more attention to the computer then her. i then told her if she had link information on her ass i would pay more attention to that then the computer. I thought it was funny but she didn't seem to find the humor in it 4
any way I think i'm going to do a cheap 3 link for now with the idea of new knuckels, trussing and high steering it when something breaks. i'll just take the stock Tie rod and flip it around then weld a drag link to it. Then i'll just make some tabs to connect the hydro to that. it looks like the brackets and links should run me around $200 to get the front 60 under the jeep. With the money I save I may be able to purchase a front locker instead of welding it.
Also rear 60 brackets just got here today cheers mbn 9 sdsfhhgdigdhfo
PostSubject: Re: The Resurection Project   The Resurection Project - Page 15 Icon_minitimeTue Feb 17, 2009 11:58 am
Good idea. you should be getting the gift cert in the mail now, 2x$50 each. they were mailed out last week.
PostSubject: Re: The Resurection Project   The Resurection Project - Page 15 Icon_minitimeTue Feb 17, 2009 4:19 pm
cool, thanks bill, I guess i'll be seeing you sat.
PostSubject: Re: The Resurection Project   The Resurection Project - Page 15 Icon_minitimeWed Feb 18, 2009 12:05 am
On the front D60's how do you get the calibers off? i removed the two bolts and tried to slide the caliber bracket off but it hits the rotor. Do you have to remove the rotor or im i missing something simple.
PostSubject: Re: The Resurection Project   The Resurection Project - Page 15 Icon_minitimeWed Feb 18, 2009 12:36 am
must be different from mine. Mine has a single bolt at the bottom attachment site of the caliper. remove the bolt and then you can tap out the little I-beam looking bracket, slides off with some effort. Then the caliper just comes right off.
PostSubject: Re: The Resurection Project   The Resurection Project - Page 15 Icon_minitimeWed Feb 18, 2009 9:47 am
got ya, I smacked that thing a few times and it never moved sepertaly from the unit and I was worried that something was going to breack. I'll wd40 it down and talk toit with a bigger hammer. I'll tell you what I really feel bad for the guys who have to move those axels around by hand. They are some heavy son of bitches.
PostSubject: Re: The Resurection Project   The Resurection Project - Page 15 Icon_minitimeMon Feb 23, 2009 11:35 am
All right I know I'm a hillbilly but at least I'm warm. Decided i needed some heat in my shack. This only lasted a day due to the fact that the smoke wouldn't go up through the hole in the ceiling.
The Resurection Project - Page 15 P2030008
Decided to do something about it so I got to work. (Yes shits a little slow for me to be doing this)
The Resurection Project - Page 15 P2110022
The Resurection Project - Page 15 P2110023
Got the floor installed and electric with a better source of heat.
The Resurection Project - Page 15 P2110028
The Resurection Project - Page 15 P2110030
Time to get some real work done. I went ahead and began to tear down the front 60. You have to love 29 years of grease and dirt. The wire wheel has great ability of taking that crap and redistributing it on your clothes.
The Resurection Project - Page 15 P2180032
Also my rear brackets came in last week so I'm goint to try to get that stuff tacked in and thrown under the jeep to see what I have. I'm still undecided on what the hell I'm going to do with the front axel. if i'm going to four or three link it.
PostSubject: Re: The Resurection Project   The Resurection Project - Page 15 Icon_minitimeMon Feb 23, 2009 2:00 pm
nice work area. you made it into something worth using. 9
PostSubject: Re: The Resurection Project   The Resurection Project - Page 15 Icon_minitimeMon Feb 23, 2009 7:42 pm
Joe do you have enough of those to make a 15 x 15 patio?
PostSubject: Re: The Resurection Project   The Resurection Project - Page 15 Icon_minitimeMon Feb 23, 2009 10:53 pm
lol! about 10 times over
PostSubject: Re: The Resurection Project   The Resurection Project - Page 15 Icon_minitimeTue Feb 24, 2009 12:31 am
want to help me set a patio under my deck at my house?
PostSubject: Re: The Resurection Project   The Resurection Project - Page 15 Icon_minitimeTue Feb 24, 2009 1:18 am
nice work shop!! i like what you've done with the place, that's great!
PostSubject: Re: The Resurection Project   The Resurection Project - Page 15 Icon_minitimeTue Feb 24, 2009 10:01 am
Depends if we got help. 15x15 with minimal digging and cutting takes me two days to do by myself. If you have a but load of digging and different angles to worry about and cut it will take a three man crew Two days to do. Also keep in mind your also going to need to install about 5 tons of cr6 give or take and 1 ton of stone dust under the two tons of brick. I can't move all all that stuff in one shot due to the fact that I can't take my big truck out of state.
Hey Nick I dubbed it the man cave. i just need some beer posters now like bill has.
PostSubject: Re: The Resurection Project   The Resurection Project - Page 15 Icon_minitimeWed Feb 25, 2009 9:25 pm
Today was a good day, I got the rear 60 tacked together and installed under the jeep today. It kind of scared me how easy it bolted up under the jeep today and how everything lined also. Only issue I had was that the brackets from balistic have a 9/16 hole and the lower CA I have use a 1/2 bolt. So I welded a washer on each side of the hole on both sides to fix the slop. Seemed to work but i'm a little worried how well they will hold up when the axel starts getting wheeled hard. Worst comes to worst i'll cut these off and upgrade to the bigger ones and swap the old ones to the front UCA. As a side note those suck down winches work well for picking up axels off the ground to get a jack back under it.
The Resurection Project - Page 15 Rearaxel1
The Resurection Project - Page 15 Rearaxel3
The Resurection Project - Page 15 Rearaxel2
I'm going to try to get the hubs and disk brakes hooked up so I can do do throw some stock tires under it and flex the suspension a little to make sure i have things correct before I put a full weld on it. I would like to leave it tacked till I get the full suspension finished front and back with the actaul tires to make sure it test right. But I'm afraid it will rust up pretty good in the next month that it takes me to get the front axel under it.
PostSubject: Re: The Resurection Project   The Resurection Project - Page 15 Icon_minitimeWed Feb 25, 2009 10:45 pm
looks cool. you could make your own thicker washers. I wouldn't trust the ones you have on there. So it looks like the uppers worked out for ya.
Number of posts : 695
PostSubject: Re: The Resurection Project   The Resurection Project - Page 15 Icon_minitimeWed Feb 25, 2009 11:09 pm
looks nice...
what does that ring that is where the diff cover bolts onto for? Does that just give support to the truss?
PostSubject: Re: The Resurection Project   The Resurection Project - Page 15 Icon_minitimeWed Feb 25, 2009 11:17 pm
connordanny wrote:
looks nice...
the HD diff cover actauly gets welded to that ring, just haven't got around to it yet.
Matt thats a good idea maybe I could make it out of 1/4" steel or something and just weld it on the outside. Or how hard would it be to just cut the RE ones off the tube and reweld balistic ones on that fit. I'm guessing not to hard, I still have plenty of thread to extend out the lowers seeing that there almost adjusted all the way in.
PostSubject: Re: The Resurection Project   The Resurection Project - Page 15 Icon_minitimeSat Feb 28, 2009 9:44 pm
okay I ended the month with a bang. For the first time since holloween night the jeep is on all for of its tires. cheers mbn 9 sdsfhhgdigdhfo
Well first after about 5 trips i finally got the disk brakes installed on the axel.
The Resurection Project - Page 15 P2280001
For the brake hoses i was kind of stumped because the hoses that come stock off the k20 wouldn't work because the hardline was to long before it turned to the soft line. So I started to look around and relized that the stock front hoses off the zj would fit the caliber and only had a short hard line making it perfect. Only prob was the bajo bolt for the k20 was a tad to big for the hose. So I drilled it out a fraction and it bolted right up.
The Resurection Project - Page 15 P2280003
Finally after a few months she's back on all four again
The Resurection Project - Page 15 P2280004
Just to see what I got I rolled the 38 up to the jeep. it looks like I'm going to have to push the axel back some and hack some more out of the rear bumper which isn't a big deal beacause I'm hoping after the axel swap is done to start working on a rear bumper with a winch mounted in it.
The Resurection Project - Page 15 P2280005
jealos-z
jealos-z
Number of posts : 604
Emploi : Mechanic
Registration date : 2007-09-17
PostSubject: Re: The Resurection Project   The Resurection Project - Page 15 Icon_minitimeSun Mar 01, 2009 11:30 am
Looks sweet Joe, Those tires look a little big cant wait to see how you make them fit lol!
Page 15 of 24Go to page : Previous  1 ... 9 ... 14, 15, 16 ... 19 ... 24  Next
» BendTech buggy project
» Project Bead Lock
» Next Project
» need help for senior project
» new buggy project
