| The Resurection Project | |
+21S h a n e MYYJROX ffhill61 lt.dan jealos-z SPP YJ mdcj7 SLeach Locked_N_Loaded 4jeepnuts The Devil Dog projblacknblue UPNOVER rockdw72 thinga'ma'rig connordanny Grason timberwolf makitupthehardway Rockn93YJ md4wheelin 25 posters |
| Subject: Re: The Resurection Project Wed Jul 16, 2008 9:35 pm | |
| Looks good Joe! keep up the good work | |
Number of posts : 695 Age : 46 Localisation : Parkville, MD Registration date : 2007-01-19
| Subject: Re: The Resurection Project Wed Jul 16, 2008 9:46 pm | |
| Nice work! Those sliders are the prettiest part of the rig right now... | |
| Subject: Re: The Resurection Project Wed Jul 16, 2008 11:25 pm | |
| - connordanny wrote:
- Nice work! Those sliders are the prettiest part of the rig right now...
at least till they hit the first rock and fall off | |
| Subject: Re: The Resurection Project Sat Jul 19, 2008 11:55 pm | |
Number of posts : 237 Age : 36 Registration date : 2007-09-12
| Subject: Re: The Resurection Project Sun Jul 20, 2008 10:53 am | |
| Subject: Re: The Resurection Project Sun Jul 20, 2008 12:36 pm | |
| thanks, dont forget were heading out again in two sats so make sure you and your dad clear out your schedule for that day.
| Subject: Re: The Resurection Project Sun Jul 20, 2008 10:31 pm | |
| The rig looks great. I like that you opted to keep the luggage racks up top! | |
| Subject: Re: The Resurection Project Mon Jul 21, 2008 6:36 pm | |
| thanks danny but i'm going to have to get rid of them when the exo roof goes on in the next couple of weeks. | |
| Subject: Re: The Resurection Project Thu Jul 24, 2008 9:41 pm | |
| Finally got the front light assembly pieced together so the jeep is getting a little closer to being street leagal. | |
| Subject: Re: The Resurection Project Fri Jul 25, 2008 9:19 am | |
| So your still trying to get tags for it? | |
| Subject: Re: The Resurection Project Fri Jul 25, 2008 8:38 pm | |
| I'll plead the 5th on that nester. | |
| Subject: Re: The Resurection Project Fri Jul 25, 2008 9:33 pm | |
| Subject: Re: The Resurection Project Fri Jul 25, 2008 11:03 pm | |
| Okay well good luck. If you have the hookups you could make it happen. The more you do the harder is gets. I love driving mine on the street. Nothing like pulling in to the gas station and everyone is looking like your on another planet. | |
| Subject: Re: The Resurection Project Fri Aug 01, 2008 10:46 am | |
| Bill quick question for you, how did you mount you tube notcher to use it. Did you go with the vise method horizontal, or vertical? Or did you mount it on a stand? | |
| Subject: Re: The Resurection Project Fri Aug 01, 2008 12:23 pm | |
| I actually did not mount the notcher. I put the tubing in a vice and clamped the notcher to the tube in the position I needed and it worked great. | |
| Subject: Re: The Resurection Project Fri Aug 01, 2008 3:33 pm | |
| hmmmm didn't think about that one, i'll give that one a try and see what happens. thanks bill | |
| Subject: Re: The Resurection Project Fri Aug 01, 2008 3:47 pm | |
| just in case some people didn't relize this, bending tube with a manual bender sucks. So far I have over 12 hrs tied up and only have the B and C pillars bent. Lucky for the internal part of the cage I only have two more easy bends to go and the rest are straight cuts. So I should have the internal cage finished for our run next sat and have the external cage finished in time for Big Dogs | |
| Subject: Re: The Resurection Project Sun Aug 03, 2008 10:11 pm | |
| All right got some work done on the cage. Before I get flamed on how high did the rear x. i did it so when i mount the spare tire on it, I will still be able to see under the tire and out the back when I need to back up. Started to work on the B hoop but ran out of time before I could finish welding in all the bars. Yes I know this is kind of a getto way to build a cage but I don't have a garage to work out of. a couple of previews of how its going to look for the internal cage. I had an extra magnet of one of my skid steers laying around and figured I'd throw it on the jeep so it could be a tax write off. I still have a lot of triangulating to do and i have take apart the rear cage so I can weld a 4x4 plates to the bottom of the pillars but it seams like its comming together. But i'll tell you what that notcher makes life real easy. I had to use a grinder to notch the middle bar on the B pillar and it sucked. Not only did it take to long, it wasn't perfect. | |
Number of posts : 1306 Age : 69 Localisation : PERRY HALL MD 21128 Emploi : New Suzuki and Used Car Sales Registration date : 2007-01-19
| Subject: Re: The Resurection Project Sun Aug 03, 2008 10:37 pm | |
| You did a great job rounding off the tail gate it almost looks like it cam that way. | |
Number of posts : 1243 Age : 42 Localisation : north harford Registration date : 2007-01-20
| Subject: Re: The Resurection Project Sun Aug 03, 2008 11:01 pm | |
| looking good. by the way I have part of a track bar. just got you message this evening | |
| Subject: Re: The Resurection Project Mon Aug 04, 2008 8:04 am | |
| no prob he just went ahead and ordered a new one. | |
| Subject: Re: The Resurection Project Mon Aug 04, 2008 8:56 am | |
| Subject: Re: The Resurection Project Mon Aug 04, 2008 10:57 am | |
| thank you sir, that tip with the nocher works real good till the hole saw starts to get dull then the notcher will grab and moves around on the tube. Also are we all still on for next weekened? | |
| Subject: Re: The Resurection Project Mon Aug 04, 2008 11:24 am | |
| Subject: Re: The Resurection Project Mon Aug 04, 2008 12:54 pm | |
| I'm still on. Are we going saturday or sunday | |
| Subject: Re: The Resurection Project | |
