| Need quick advice; what plugs w/HEI conversion? | |
FallstonYJ Open/Locker
Number of posts : 45 Age : 63 Localisation : Fallston Registration date : 2008-04-07
| Subject: Need quick advice; what plugs w/HEI conversion? Sat Nov 01, 2008 11:55 am | |
| Need some quick advice; I am trying to get my HEI conversion installed today but I can't seem to get any straight advice as to what kind of plugs to install with it. It is an 88 YJ with the 4.2. I bought the HEI distributor from 4WD Hardware and a set of Livewires. Figured I might as well replace the plugs at the same time. I have read a couple of posts that say Platinum plugs burn too hot; one conversion write-up went with Bosch Super plugs; had 2 people tell me not to use anything but plain old Champions. Anybody have experience with some solid advice? I would really like to get this thing installed today. Thanks for your time, Tom | |
| Subject: Re: Need quick advice; what plugs w/HEI conversion? Sat Nov 01, 2008 12:32 pm | |
| I would think champions My brother had champion on his, but i came with it on there so that is what we reused. But that's not really solid advice | |
| Subject: Re: Need quick advice; what plugs w/HEI conversion? Sun Nov 02, 2008 9:03 pm | |
| just use the same champion plug you use on the stock set up and gap it to .045 that is what I did on mine. This set up get you to use a wider gap on the plug. | |
CamoK5 Locker/Locker
| Subject: Re: Need quick advice; what plugs w/HEI conversion? Sun Nov 02, 2008 10:42 pm | |
| I second what Paul said, stay with what ever type of plugs you like just increase the gap to .045 . | |
| Subject: Re: Need quick advice; what plugs w/HEI conversion? Mon Nov 03, 2008 10:43 am | |
| Thanks for the replies; I didn't get around to installing it over the weekend so hopefully I can get to it today/tomorrow. The intructions that came with the distributor said to use a gap of .050 to .055. You recommend .045? | |
| Subject: Re: Need quick advice; what plugs w/HEI conversion? Mon Nov 03, 2008 12:59 pm | |
| I feel that is what I set mine to, Also you will need bigger wires the stock 258 wires are to thin I think it's a 8MM wire you need. I got a set for a chevy straight 6 the came with the HEI stock. | |
| Subject: Re: Need quick advice; what plugs w/HEI conversion? Mon Nov 03, 2008 1:35 pm | |
| Thanks, Paul. I bought a set of Livewires to go with the HEI; they were expensive but they are pretty substantial! | |
| Subject: Re: Need quick advice; what plugs w/HEI conversion? Tue Nov 04, 2008 10:44 am | |
| Well I got the HEI conversion done last night; I went with the standard Champion plugs. So far I am not real pleased. The Liverwires were not a good fit at all; at $90 I expected much better. I haven't taken the Jeep out on the road yet but I really don't notice any difference in how it runs so far in the garage. Oh well, I guess time will tell! | |
| Subject: Re: Need quick advice; what plugs w/HEI conversion? | |
