 Emergency brake ideas needed.
PostSubject: Emergency brake ideas needed.   Thu Apr 01, 2010 10:40 am
ok i have the rear D60 from teh 79 ford but the disc brake conversion did not include calipers that accomodate an emergency brake. Any ideas?
PostSubject: Re: Emergency brake ideas needed.   Thu Apr 01, 2010 11:27 am
http://www.highangledriveline.com/e_brake.html
MonsterS10
Number of posts : 267
PostSubject: Re: Emergency brake ideas needed.   Thu Apr 01, 2010 3:38 pm
The driveshaft brake kind gets in the road you can get cadilac calipers with the e-brake on them or mechanical line locks
PostSubject: Re: Emergency brake ideas needed.   Thu Apr 01, 2010 8:31 pm
i thought about caddy calipers but i rememberd that Kat's were a PTIA to adjust. what year caddy?
PostSubject: Re: Emergency brake ideas needed.   Fri Apr 02, 2010 2:25 am
I heard they were a PITA but maybe the only option
I'm dumb
My dog ate my turtle
PostSubject: Re: Emergency brake ideas needed.   Fri Apr 02, 2010 2:36 pm
the best emergency brake ive used was a large oak tree lol!
MARR step up or step out
PostSubject: Re: Emergency brake ideas needed.   Fri Apr 02, 2010 2:44 pm
I strongly agree, works with the YJ anyway but I don't think that will pass inspection.
bleoh
Open/Open
Open/Open
Number of posts : 4
Registration date : 2008-09-29
PostSubject: Re: Emergency brake ideas needed.   Tue Apr 06, 2010 11:55 am
I forget where I saw this idea, maybe Pirate. Anyway, they took their e-brake cable and routed it back through the firewall just in front of the brake pedal and attached it to the pedal.
Not sure if it would pass or not, or if it is even a good idea. Just thought I would throw it out there.
Brian.
PostSubject: Re: Emergency brake ideas needed.   Tue Apr 06, 2010 4:33 pm
Brian.
http://pirate4x4.com/forum/showthread.php?t=859210&highlight=parking+brake
I was just reading a thread on pirate the other day which had a shut off valve plumbed to the cutting brakes. Didn't find what I'm thinking of yet...
PostSubject: Re: Emergency brake ideas needed.   Tue Apr 06, 2010 5:39 pm
The High Angle Driveline pinion brake is not going to work, not anywhere even close to being enough room to fit in there. Back to 2 choices,
1. line lock
2. caddy calipers
Eskimo
Number of posts : 76
Registration date : 2009-10-20
PostSubject: Re: Emergency brake ideas needed.   Tue Apr 13, 2010 3:56 pm
I've yet to see a set of Eldorado calipers that would hold a rig on even a moderate hill. If it's only for some kind of road inspection, then OK, but they suck otherwise.
I have a ball-valve on my rear brake line and it works, though I don't trust it (my own paranoia). It ends up being used more for doing front digs.
PostSubject: Re: Emergency brake ideas needed.   Tue Apr 13, 2010 10:25 pm
only to pass inspection. it is an auto and trees work fine for me
Eskimo
PostSubject: Re: Emergency brake ideas needed.   Fri Apr 16, 2010 12:57 pm
Then by all means...
The Eldo calipers are hydraulically the same as the Chevy monte Carlo calipers Toyota guys use all the time for rear discs.. 1" bore MC works really well.
MonsterS10
PostSubject: Re: Emergency brake ideas needed.   Fri Apr 16, 2010 3:10 pm
I think if you read the rules your allowed to use electric linelocks very simple fix i do remember having a hard time finding the cable brackets for the caddy calipers remans usually don't come with them
PostSubject: Re: Emergency brake ideas needed.   Fri Apr 16, 2010 6:00 pm
I already ordered the set from http://www.tsmmfg.com/ and they actually come with the levers and such.
» Goalkeeper needed for Saturday - Leicester City Supporters
» Welding help Needed..
» Referee needed
» RZR Parking Brake Threads
» Rhino Rear Brake?????
