| Homemade TC skid? | |
06rubicon Open/Locker
Number of posts : 26 Age : 48 Localisation : Frederick Registration date : 2007-01-20
| Subject: Homemade TC skid? Sat Jan 20, 2007 6:11 pm | |
| Has anyone tried or seen a homemade TC skid for a TJ? I've got a friend that works at a scrap yard and saved me a piece of 3/8"s AR steel like they use on the body of tanks. He has all the tools to make it at work and the yard fabricator has offered to help too. The stock shovel has got to go and I'd like to tuck the TC up a little. I'm sure I'l need a BL, MML or both if I want to raise the TC. I'd be real happy if I could get it flush with the frame rails but I don't think there is enough clearance in the tub. Anyone got any ideas or seen a template? Ryan | |
onemoretime Admin
Number of posts : 196 Age : 24 Registration date : 2007-01-18
| Subject: Re: Homemade TC skid? Sat Jan 20, 2007 7:09 pm | |
| Ryan, How flush to the frame you can make it will depend on how much BL you use and or how much sheet metal fab to the tub you want to do. If say you used a 3" BL and 1" MML. You then should have enough clearence to make it flush. Remember though that you will need a CV driveshaft if you go this high. If you want tuck it up a lttle higher like 1-1.5"'s then you will not need the MML. Template wise this will be custom fab unless you go with something from Teraflex or Medic doctor as they have bolt in hi mount TC skids. I beleive Tera sales theres with a 1" BL for the TJ. For a template you would need you measurements from hole to hole and then the amount of the tranny mount and a few other things. If you go flush that would be your easiest as no bulge would need to be there. I know this turned into a long reply. Sorry. Another thing to keep in mind if going flush would be do you really want to mount the TC to the bottom of the Jeep? Where the bolt will now get ground down as you climb over things. Or do want to make new mounts that go through the side of the frame where they cant snag on things. One last thing do you really want to use something that is that heavy. I know it wont bend but that seems really heavy. And that is my .02 | |
| Subject: Re: Homemade TC skid? Sat Jan 20, 2007 7:32 pm | |
| Well i don't want to do a 3" BL I can tell you that much. I've seen alot of lo-pro TC skids on the market but I like Jeep Medics alot. I think I might try to use a design simular to theirs. I think theirs raises it about 2" and they recommend a 1" BL. I've got a CV shaft & adj. rr upper CA's so I think I'm good there. I guess that leaves a BL & MML. I think I'll just drop the factory skid and use it as a template.
Do you really think 3/8" will be to heavy? He told me its the same weight as steel it just has carbide(?) in it.
I think it would be interesting project plus I would get to use all the fun tools at his shop like the die press, plasma cutter and the biggest press I've ever seen in my life!
Ryan | |
onemoretime Admin
| Subject: Re: Homemade TC skid? Sat Jan 20, 2007 8:05 pm | |
| Ryan, I say go for it. I am all in for fab work. Do i think it will be to heavy? To me yes, but it will be indestructible. For someone who wheels their rig and uses it has a DD. Weight really isnt an issue. Im trying to lighten mine up as much as possible. But that is because of competion. Also since i will be making my own hi TC. Much like what you doing. I would look into riasing the mounting points toi the side of the frame. Im going to cut 11/8" through the frame and weld in tube so i can use shackle bushings and greasable bolts to keep things from freezing up. This way the TC skid bolts through the frame and the bolts are out of the way. Just my thoughts tho. Other then that go for it. Cant wait to see it. | |
| Subject: Re: Homemade TC skid? Sat Jan 20, 2007 9:15 pm | |
| I think your might be right about the 3/8", he's going to look for some 1/4" or 5/16" for me. I'll keep in mind about the mounting points but I really don't won't to start cutting/boxing the frame, maybe once it's paid for . I think I'm going to pull the stock skid next weekend and get started. Any other suggestions out there? | |
| Subject: Re: Homemade TC skid? Sun Jan 21, 2007 7:09 pm | |
| - 06rubicon wrote:
- I think your might be right about the 3/8", he's going to look for some 1/4" or 5/16" for me. I'll keep in mind about the mounting points but I really don't won't to start cutting/boxing the frame, maybe once it's paid for .
Any other suggestions out there? Contact Mike (treefrog)...Mike has an 04 Rubi... he is running the Jeep Medic skids... swears by them. This is probably the skids I will get shortly myself... Needs the 1" motor lift... he used a MORE lift, but said the right mount was tough... We talked at great length about it over the CHristmas weekend while we took off my hardtop and put on his rig. | |
| Subject: Re: Homemade TC skid? Sun Jan 21, 2007 8:11 pm | |
| Tony Performance Offroad has the motor mount kit with the built in motor mounts. that way you get stronger motor mounts. The kit they have cost a little more but its a nice up grade when I have seen stock motor mounts break twice. once was in a TJ that I still dont understand why. Second was in eric millers rubicon that snaped after we rolled it back over.
I myself and talked about doing the same thing with Rich and Randy Wood. We figure on a YJ the 2 in. BL and the 1 motor mount lift will allow me to run a Flush with the frame rails skid. | |
| Subject: Re: Homemade TC skid? Sat Jan 27, 2007 5:03 pm | |
| Sorry I haven't replied lately...I've been in lovely Des Moines, Iowa with 10 degree weather for the past week :bonk:
Thanks for the input Nester, I'll keep it in mind. I think I might give the homebrew skid a try if it doesn't work out like I hope I'm going with the Medic. | |
| Subject: Re: Homemade TC skid? Sun Jan 28, 2007 12:58 pm | |
| Nester let me know what you end up doing. I am also looking at dropping the jeep 2 inches and going flush with the frame with the skid. I clocked the Atlas up and "clearanced" the body a little to make it tuck up really tight. I will be doing this project and will likely need the engine lift and a 1 1/4 BL. I will measure first since I may not need to go with the body lift if the transfer case was clocked up enough. As for a TJ I'm not sure. Randy suggested to me attaching 1" or so square stock under the frame rails and going with a flat steel under that to make the underbelly flat. It would rid you of the scoop anyway. | |
| Subject: Re: Homemade TC skid? Sun Jan 28, 2007 12:59 pm | |
| Another thought. Why not modify the stock skid. Cut off the scoop and if needed weld some metal on to strengthen it up again. | |
| Subject: Re: Homemade TC skid? Mon Jan 29, 2007 12:39 am | |
| Well the stock skid sucks to start with its weak and once you start running on it really hard it starts to bow up ward. Mine is in bad shape as is. Everything that I have read and seen says that you need a 1 1/4 BL and 1 inch motor lift. I'm still working on the details. I might need a CV front drive shaft but. The project is not that high on the list. I need to build up the axles first. That and I'm working on getting a 4:1 transfer case | |
treefrog Open/Locker
Number of posts : 28 Age : 56 Localisation : Fort Drum, NY Registration date : 2007-01-21
onemoretime Admin
| Subject: Re: Homemade TC skid? Thu Feb 01, 2007 2:15 am | |
| sure can. But if you have wheel weights and a acetolyne torch and some goop. And you are not affriad of starting a fire it can be fixed | |
| Subject: Re: Homemade TC skid? | |
