 slip yoke for driveshaft w/ 1350 joint
88blazeron40s
88blazeron40s
Number of posts : 280
Emploi : EDMS
slip yoke for driveshaft w/ 1350 joint Empty
PostSubject: slip yoke for driveshaft w/ 1350 joint   slip yoke for driveshaft w/ 1350 joint Icon_minitimeThu Jul 15, 2010 8:20 am
i need a driveshaft end that has a 1350 joint in it
MonsterS10
MonsterS10
Number of posts : 267
PostSubject: Re: slip yoke for driveshaft w/ 1350 joint   slip yoke for driveshaft w/ 1350 joint Icon_minitimeThu Jul 15, 2010 9:35 am
Are you sure its 1350 ford used 1330 the same width as 1350 but 1310 dia. if its 1350 one ton chevy at transmission
88blazeron40s
88blazeron40s
Emploi : EDMS
PostSubject: Re: slip yoke for driveshaft w/ 1350 joint   slip yoke for driveshaft w/ 1350 joint Icon_minitimeThu Jul 15, 2010 10:07 am
i will have to check that but i put the 1310 i have up against the 60 yoke and it didnt look like it was close at all
PostSubject: Re: slip yoke for driveshaft w/ 1350 joint   slip yoke for driveshaft w/ 1350 joint Icon_minitimeThu Jul 15, 2010 10:48 am
Will my old yokes be of any help? I have the old driveshaft from the CJ rear taht i accidently put in the YJ(the one we had to beat to death on Bunny trail to get to slide at the slip yoke. I will be removing that shaft to put the correct one back in. You are welcome to it. I can check it today to see if it still fits the D60 yokes to make sure it is a match. I'll be home just after noon today to find out. text or call me then.
88blazeron40s
88blazeron40s
Emploi : EDMS
PostSubject: Re: slip yoke for driveshaft w/ 1350 joint   slip yoke for driveshaft w/ 1350 joint Icon_minitimeThu Jul 15, 2010 11:09 am
ok cool bill thanks and was your front 60 a 1330 u joint at the yoke
PostSubject: Re: slip yoke for driveshaft w/ 1350 joint   slip yoke for driveshaft w/ 1350 joint Icon_minitimeThu Jul 15, 2010 11:59 am
isn't that the stock size? or did some come with 1310?
PostSubject: Re: slip yoke for driveshaft w/ 1350 joint   slip yoke for driveshaft w/ 1350 joint Icon_minitimeThu Jul 15, 2010 12:06 pm
I think they may be 1310 since that is what i am using on the YJ and the u joint from the CJ did fit my yoke.
If the splines on the shaft are the same as what you are using then maybe you can take the half of the driveshaft with u joint and my yoke and just run the 1310 if that is what it is.
MonsterS10
MonsterS10
PostSubject: Re: slip yoke for driveshaft w/ 1350 joint   slip yoke for driveshaft w/ 1350 joint Icon_minitimeThu Jul 15, 2010 12:40 pm
The chevy & dodge 60 usually had 1310s Ford for somereason usually had 1330
88blazeron40s
88blazeron40s
Emploi : EDMS
PostSubject: Re: slip yoke for driveshaft w/ 1350 joint   slip yoke for driveshaft w/ 1350 joint Icon_minitimeThu Jul 15, 2010 12:51 pm
yeah i might do that but i saw they have a 1310x1330 ujoint that would fit for both
MonsterS10
MonsterS10
PostSubject: Re: slip yoke for driveshaft w/ 1350 joint   slip yoke for driveshaft w/ 1350 joint Icon_minitimeThu Jul 15, 2010 1:48 pm
Buy 2 for some reseaon they seem to brake easy just broke on the willys last week screwing off at the house broke the joint & driveshaft ears
88blazeron40s
88blazeron40s
Emploi : EDMS
PostSubject: Re: slip yoke for driveshaft w/ 1350 joint   slip yoke for driveshaft w/ 1350 joint Icon_minitimeThu Jul 15, 2010 5:08 pm
yeah thats what the thread on pirate said too
PostSubject: Re: slip yoke for driveshaft w/ 1350 joint   slip yoke for driveshaft w/ 1350 joint Icon_minitimeThu Jul 15, 2010 9:56 pm
yes 1330 is ford. because I upgraded mine to 1350. Also isn't 1310 the stock jeep joint.?
PostSubject: Re: slip yoke for driveshaft w/ 1350 joint   slip yoke for driveshaft w/ 1350 joint Icon_minitimeThu Jul 15, 2010 10:09 pm
For some reason my 79 ford axle came with 1310 joints. Fit my YJ which has the stock 1310 joints.
PostSubject: Re: slip yoke for driveshaft w/ 1350 joint   slip yoke for driveshaft w/ 1350 joint Icon_minitimeFri Jul 16, 2010 12:10 am
thats odd scratch
» got a good link to tech stuff. put it in here.
» Front Driveshaft U-Joint replacement
» stock d60 yoke
» johnny joint
» Rear U-joint
 :: For sale :: Wanted-
