| The Resurection Project | |
+21S h a n e MYYJROX ffhill61 lt.dan jealos-z SPP YJ mdcj7 SLeach Locked_N_Loaded 4jeepnuts The Devil Dog projblacknblue UPNOVER rockdw72 thinga'ma'rig connordanny Grason timberwolf makitupthehardway Rockn93YJ md4wheelin 25 posters |
| Subject: Re: The Resurection Project Tue Mar 02, 2010 10:06 pm | |
- This is true, Joe whats next?
To be honest this project is winding down. all I got left is the rear bumper and front coilovers. Once thats finished I'm going to start on my go fast project in order to keep up with bill and kim General plan is tobeat the shit out of the jeep then take all the running gear from the jeep and swap it over once the ranger is finished next year some time. The coilovers are sway-a-way 2.0 remote reservoirs, 2007, 14" travel, triple rates.. front springs were 110/150 and rears were 80/130. Im using the fronts for the rear now and really haven't decided what weight i'm going to run in the front yet. As for that run on the 13th I probably wont be able to make it since i'm just going to tear into the front once i finish up the rear. | |
| Subject: Re: The Resurection Project Tue Mar 02, 2010 11:20 pm | |
As for that run on the 13th I probably wont be able to make it since i'm just going to tear into the front once i finish up the rear. Come again? | |
| Subject: Re: The Resurection Project Wed Mar 03, 2010 12:26 am | |
| 60's and coilovers to be more specific. Probly run a built 5.0, some sort of tranny and an atlas. | |
| Subject: Re: The Resurection Project Thu Mar 11, 2010 8:01 pm | |
| Hey Joe, There are 2 rangers for sale on the RC site for cheap... http://www.rc4x4.org/rcforum/index.php/topic,9087.0.html | |
| Subject: Re: The Resurection Project Fri Mar 12, 2010 10:09 am | |
| Thanks for the heads up danny but i own two rangers already Any way it looks like my shake down run for the jeep is going to be at the end of march at crozet. The guy from trucks wanted to do a run there so he dropped m a line to see if I wanted to tag along with him, conti, matt and adam. I'm not going to have time to get the front coilovers finished but should be able to get everything else worked out on it. i sat down and made a list and have about two pages of little things that need to be done so it will be cutting it close, but hell when is the rig no fully torn down two days before a run I keep forgetting to take a camera with me but I have the rear bumper tacked in. I won't win any fabrication awards on it but at least it will get the job done (I hope) | |
| Subject: Re: The Resurection Project Fri Mar 12, 2010 2:47 pm | |
| Sadly I may of lost that title the last few weeks of moving the shop. After i realized how much shit I had to move from one shop to the next, i said screw it and got a roll of and began to fill it with the loaders. It took me 2 weeks with 3 machines 2 trucks and 3 trailers to move everything that i was not throwing away. Of which a full size roll off truck had a hard time picking up the trash.
But dont worry i still had enough to fill two 40' containters inside and on top, my 50 x 50 building and all surrounding parking lot space. When I say filled it to the point you can't walk in between stuff.
Unlike the hoarder I actually sell my junk to people like you at top dollar who realize they need some small little object they cant find easly. It seems here lately everyone needs some sort of odd automotive thngmajigit. It may take a few years on some things but still least its there when i need it. | |
| Subject: Re: The Resurection Project Sun Apr 11, 2010 9:22 pm | |
| Subject: Re: The Resurection Project Sun Apr 11, 2010 9:52 pm | |
| Subject: Re: The Resurection Project Mon Apr 12, 2010 5:27 pm | |
| Subject: Re: The Resurection Project Tue Apr 13, 2010 12:46 pm | |
| Subject: Re: The Resurection Project Tue Apr 13, 2010 12:49 pm | |
| Glad to see you got tunes! | |
| Subject: Re: The Resurection Project Thu Apr 15, 2010 8:02 am | |
| Subject: Re: The Resurection Project Thu Apr 15, 2010 8:03 am | |
| Subject: Re: The Resurection Project Thu Sep 02, 2010 10:53 pm | |
| Well its been a few days since I've updated this thing so here it goes. I fixed the broken drive shaft and finally went with a round one that i fabbed out of 2" .120 wall. Dropped the tranny pan and found this, which i'm pretty sure is not good I also located were my axle wrap was coming from on the front axle Anyway i got that all fixed and headed out to GSNE were i proceeded to set a new record. Unfortunately it was the record for the most damage with one press of the gas. I was at RC doing a hill climb at the end of walk in the park when the factory welds on my upper CA joints let loose. This In turn started a chain reaction of an epic scale. Any way to make a long story short when the UCA joints broke it let the pinion rotate up. This in turn snapped my pinion yoke and drive shaft. When the broken driveshaft spun it tore out various lines out from under the jeep and exhaust system . IT at some point also snapped the end of my TC off. while all this was happening the pinion kept rotating up snapping off both my coil overs which in turn let the body slam down on my new tires cutting the shit out of them. So lets just Say with all the stuff broken it made for quite an interesting recovery. So after a marathon I got the jeep ready for big dogs the following weekend were it ran pretty good all weekend except for a few minor probs. One of which was my RE HD track bar bracket was hitting my truss. So i cut the bottom half off and re fabbed that. And leaky diffs which were fixed with some lube lockers. I also noticed a lout click comming from the front end of the jeep. I figured it was the u joints going bad so I replaced them along with all the bearings in the front of the jeep. Well with that complete i headed down to harlan for GSSE were I ran it hard and shook out a few more bugs. First being I found out were the click was comming from in my front end. it was my track locker ging up to the point were it wouldn't even lock up. i figured all the teeth would be gone but when I pulled it I found that wasn't the case Everything was fine on it including the teeth. i guess the v8, 5.13 gears, and 38's are a little to much for it. i think im just going to toss it into my 06 f350 and run it in there till it blows up. I also stripped out a hub which is no big deal. I have 35spline hubs and my 35 spline outers should be here any day. I also kept blowing my hydro line that comes out of my hydro pump. I'm going to need to build a new line for this so my jeep doesnt try to burn it self to the ground again. Also pick up a set of reid knuckles which ill try getting installed sometime over the winter when I go to chop the front end of the jeep off. | |
| Subject: Re: The Resurection Project Thu Sep 02, 2010 11:08 pm | |
| WOW! | |
| Subject: Re: The Resurection Project Fri Sep 03, 2010 1:58 am | |
| your driveshaft is out of phase. | |
| Subject: Re: The Resurection Project Fri Sep 03, 2010 10:45 am | |
| Not sure what you did with the locker but I bet its just a matter of getting a spring kit. I know the springs in those things tend to go bad over time. | |
| Subject: Re: The Resurection Project Fri Sep 03, 2010 8:20 pm | |
- Not sure what you did with the locker but I bet its just a matter of getting a spring kit. I know the springs in those things tend to go bad over time.
with less then 7 trips and maybe 30 road miles on it? - rockdw72 wrote:
- your driveshaft is out of phase.
not any more, that one got snapped off | |
| Subject: Re: The Resurection Project Fri Sep 03, 2010 11:31 pm | |
| gonna rebuild those coilovers? | |
| Subject: Re: The Resurection Project Sat Sep 04, 2010 4:51 pm | |
| yes, but not probably till winter time when I do the front clip. After big dogs i'm going to roll the white jeep into the shop and began cutting it up for the front clip that will be swapped over to the green one. | |
| Subject: Re: The Resurection Project Thu Sep 30, 2010 6:47 pm | |
| quick update, sent the power steering pump back to psc. They said it had a sticking valve and that was the reason it wasn't working right. They said they repaired it and should of shipped it out yesterday. Also finally got around to cutting down my one chevy outer to fit my ford hubs. Seems like that did the trick, everything bolted up, engaged and disengaged. So I finaly have 35spline outers all the way around | |
| Subject: Re: The Resurection Project Thu Sep 30, 2010 11:17 pm | |
| Subject: Re: The Resurection Project Wed Oct 27, 2010 9:56 am | |
| I picked this jeep up a while back but haven't got a chance to mess with it. Some of you may remember this jeep, its bruce's old jeep. Its in need of some TLC. General plan is to put as little money as possible to get it somewhat road worthy and a little light trail worthy with 32s or maybe 33s. Bruce had a 231 laying in the back of it that was ready to bolt in. i decided to pull the 242 out of my rig and throw that in his jeep. This way it opens up more options for the trail rig in the gearing department. Now this bring me to the trail rig. okay after running it two weekends in a row and not breaking anything (Which I havent done since I decided that 33's weren't big enough) I think ive chased out most of the bug. So thus this means its time to change everything again. Thus this brings me to a cross roads on were to go with it next. Number one goal is to loose at least 500# The general plan is to cut every off from the fire wall forward and tubing it out. This way i can get rid of the ARB (which ill put on bruce's jeep) and get a better approach angle. Also it will allow me an easyier time mounting the C.O.s Which opens pandora's box. now would be the time to do something about the drive line. I really have no issues with the power but the Xfer case gearing needs to be addressed. i have 5:13 gears FWI options 231 with a 4 to 1 231/d300 231/231 atlas different driveline with some other xfer case Right now time and money is an issue. i know the atlas saves time but the 2k plus price tag would put me some were far into next season to purchase. I'm thinking 231/d300 since the 4:1 kit is only 500ish compared to the 4:1 on the 231. but i'm thinking that the extra cost of finding and purchasing a d300 will offset the cost. Ikow im kind of rambling but i'm trying to get a game plan together since I plan on starting the tube work in dec on the mock up rig and having it transfered over to the trail rig by late april for big dogs. this is how it sits now. | |
| Subject: Re: The Resurection Project | |
